After applying the NXT Tech Wax using the G-100 Dual Action Polisher and allowing it to dry for approximately 15 minutes, we put a new, dry W-8006 foam polishing pad onto the Velcro backing plate and slipped on a Meguiar’s M-9920 Ultimate Bonnet, (a microfiber polishing bonnet). These ultra soft microfiber polishing bonnets do and excellent job of remove the Tech Wax while leaving behind a clear, high gloss finish.
I'm pretty sure this was the first time this member had ever used a G-100 dual action polisher. Here he is using the M-9920 Ultimate bonnet, (a microfiber polish bonnet for removing polish and wax), to remove the NXT Tech Wax.
Notice how he has the electrical cord draped over his shoulder to prevent the cord from coming into contact with his Truck's finish.
The NXT Tech Wax and Meguiar's microfiber bonnet on a dual action polisher produces a mirror finish...
Check out the crystal clear reflection of the neon Meguiar's sign in the finish of the hood as well as the lights and the reel that holds the power cord after the Tech Wax has been removed.
At the same time, the other Ford Lightning Truck was getting the same treatment, here the owner is removing the Tech Wax with a microfiber... The color of this truck is Crimson Red, which was very different than the other red Ford Trucks here today.
Check out the extremely clear, high gloss results...
