Update on mustang engine issue.
  • 03mach1
    replied
    Re: Update on mustang engine issue.
    I am still am replacing the o2s the code is gone but I will replace it anyways. It could be bad or it might not be bad. I am going to replace it tommorow. And yes it was worth it. I am actually glad to do it myself. I gained a lot of knowledge just by working on it today. Now i see why people take their car to a dealer to get it fixed. I did put some more lucas fuel injector cleaner in it and my MPG has gone up so I do not think it is a injector or anything dealing with the fuel sys.
  • J. A. Michaels
    replied
    I am glad you solved the problem. New plugs and wires. Your Mustang should be screaming down the road.
  • roushstage2
    replied
    It may have been a pain in the butt getting to them, but a shop would have charged about $200-$300 to tell you that! Glad you are getting it figured out, especially on your own. The experience gained is well worth it!
    Did that fix the code? If not, I'd still say it is the O2 sensor.
  • Nappers
    replied
    Good that is was a "simple" thing, not a bad injector, fuel regulator, dead cylinder etc etc.
  • 03mach1
    started a topic Update on mustang engine issue.
    Well I changed all my spark plugs, it took a while (3 hours) I had to get a special socket that is desiged for getting into small holes. because the manifold was covering up a little bit of the hole. but what I found was a severed spark plug wire. it had a huge gash in it. never saw it when i bought it but I super glued it and wrapped it up with electrical tape for a temporary fix. I will post pics later of all the spark plugs. I had to take off my strut tower brace, and intake with a couple of vacuum lines. But now so far it has not backfired under hard accel. I tested the car and seems to be alright. I will buy a set of wires soon.
