If it's below the clear coat, then compounding will not fix the problem.
If it were mine, I would do a simple test in a small area using ScratchX, a hand applied paint cleaner, and then compare it to the surrounding area. If the test area looked better, then I would either continue to apply the ScratchX to the entire affected area, or machine clean the area probably with either a PC or a Rotary Buffer. I'm a rotary buffer kind of guy, so that's probably the direction I would lean.
Here's a tutorial on how to use the ScratchX,
If you really want to do the test the right way, get some blue painters tape and tape off an area in the middle of the affected area, along the side of the scoop about 6-8 inches long in the direction of the length of the hood. Then apply the ScratchX to this area. Apply at least 2 applications of ScratchX using the directions included in the link above. Then wipe off the residue, remove the tape and inspect your results in good lighting.
If you see an improved difference, then you now the problem is on the surface. If you see no change at all, then chances are good, that the problem is below the surface.
If the problem is in fact below the surface, then you should talk to your painter. This might not be his fault, but it is where the problem will have originated and in order to make it right, the hood will have to be repainted.
