Originally posted by 6spdvette
okay thanks that would be fine. can you just answer this the reason it's not happening all over is because the hood is the only place that has bondo on the car. so that would explain it know??
The bondo is under the basecoat and under the clear coat, anything you apply to the surface would not interact with the bondo because, it would never come into contact with it.
That's why I said that the problem has probably always been there, it's just now, that you have noticed it. Tech wax tends to create a very clear finish enabling your eyes to see the underlying color of the basecoat. In this case, it cleared up the clear coat to such a level that now you can see the yellowing you describe.
Your question,
Can you just answer this the reason it's not happening all over is because the hood is the only place that has bondo on the car. so that would explain it know??
Can you just answer this question. The reason it's not happening all over, is because the hood is the only place that has bondo on the car. So what would explain this?
I can't answer your question because so far, I don't' think it's the Tech Wax that is causing the problem. You claim our wax changed the color of your cars paint where the bondo is, but the Tech Wax has never come into contact with either the bondo or the white basecoat? So how could it affect it?
How many coats of clear did your painter apply? It would only take one coat of clear paint to seal the basecoat, (sprayed over the bondo), and most painters spray a minimum of 2-3 coats and in the case of a show car, more to give them some material to remove in the wet-sanding procedure and still leave plenty of film build for the future.
If your car's finish was reacting to NXT Tech Wax, (the upper surface), it would react uniformly over the entire finish, assuming it's all one type of paint. By this I mean if your painter sprayed the same brand of paint over the entire hood, (which only makes sense), then if there was a reaction with the paint, it would be over the entire surface, not in isolated areas. Problems in isolated areas sounds like something that was caused by surface prep, not something you pour out of a bottle after the fact.
This truly sounds like a problem that is under the clear coat. Of course, it's hard to say without being there to see it first hand.
Nothing else makes sense.
I understand you're merely posting what you see, but that's why I said perhaps what you're seeing now is the result from the Tech Wax making your clear coat completely clear so that you can in fact see the discoloring you say is present.
