Ferrari F40 hatch
  • Ferrari F40 hatch
    Any Megs recommendation to polish the plastic hatch on an F40?
    Re: Ferrari F40 hatch
      Can you comment on its application and removal?
      Compare it to anything like M205 or D151?
        As mentioned above, PlastX is the perfect product for that surface because it is specifically designed for "clear plastics".
        As far as your question goes, a good clean foam applicator for application and a clean dry premium microfiber like our Supreme Shine for removal....The removal cloth will be your key as to not re-scratch the surface.
        Do the inside and out, and let the product do the work for you...Smooth even application, and no need to let the product dry. Simply wipe it off while it is still wet.
        Mike Pennington
        Meguiar's, Inc.
        800-854-8073
        mpennington@meguiars.com
          Thanks Mike.
          Is machine application recommended?
            It is really up to you to determine what the situation needs... How bad is it and what are the expectations of the owner?
            When you say machine, do you mean D/A or rotary ?
            D/A - You could use PlastX with ease on a polishing or finishing foam pad...
            Rotary - You should switch to M03 Machine Glaze and a foam polishing pad...
            Least aggressive is best, so if it not that bad, you can probably work it by hand and get pretty good results !
            Mike Pennington
            Meguiar's, Inc.
            800-854-8073
              If PlastX isn't aggressive enough to get the results you are looking for, we've had excellent results with both M105 and M205 on clear plastics via the PC and 4" pads. As always test from least aggressive to most aggressive
                Going by the photo,it looks clear enough to be done by hand.Photos don't always pick up well,but looks good.
                  Yea what he said -
                    Originally posted by Superior Shine View Post
                    Yea what he said -
                    Should have known Superior Shine had already done one.
                      The hatch is in surprisingly good shape. Very, very minor swirling.
                      I assumed that it was a cover to a 478hp engine, it was durable and heat resistant.
                      But I didnt want to go only on assumptions....
                      Thanks for posting the shot of the rotary on it.
                        I just wanted to remind everybody that Jose doesn't rock like Toe.
                          showoff
                            Oh you guys ****...
                            To be around what I consider the ultimate Ferrari (or at least the ultimate one of the last 3 decades) is truly amazing.
                              The car maybe fast and a Ferrari and all that but I wasn't impressed by the fit and finish. The interior was very sparse and crude. It was a straight up race car and not much of a work of art like other cars are.
