Re: Need Advice On Appropriate Backing Plate, Pads, Products
First, let's remember the problem is this car was neglected for a very long time and has multiple layers or types of defects. In terms of maintenance, these are the types of damage we are trying our best to avoid using various washing and detailing techniques, although rock chips/rashes are inevitable from driving. In terms of correction, what works for one type of defect is pointless for another, and those of us commenting have different experiences and comfort levels. You ask great questions, too, NYShine!
Spiderwebs: So, the spiderweb and swirl marks are among the easier problems you have. Those should be quick enough work with M105, and I would go over the whole car. Followed by an equally thorough polish step with perhaps two or more passes, and then a wax/sealant step, this typical correction process will solve a LOT of the superficial defects and yield a stunning black finish. This will also allow you to see and evaluate the remaining defects in a whole new light.
Etchings: Next up, you have deeper etchings. Some etchings, or parts of etchings, will come out or be faded down just from the M105 passes, but some will still be there after you've made it through the waxing. In some of those cases, I have suggested a bit of very careful sanding and filling, but I'd evaluate that after being done with the regular correction above. Some of the spots may be addressable by filling them with a bit of paint/clear and then finely polishing to reduce their appearance, some of them you may decide aren't worth worry.
Chips: Next again, you have rock chips and other types of chips that seem to go right to primer and/or bare metal. These are very common and cannot be fixed with any DA polishing technique. Unless you're going to machine sand and airbrush matching paint and clear like a paint blender would, the only way to repair them (or hide them) without repainting is to do spot repairs. As I've said, I use a paint pen along with sanding techniques with 1500/3000, and then I use compound to pull out the sanding marks.
For me, and not least because I'm dealing with black paint, some chips I've been able to make completely disappear, others not so much - that is, perhaps a crater remains that I can later work on again - but at least the metal is protected, and they are matching black spots instead of grey/white ones. Again, sanding techniques are something you need to read up on and test. Here is a very helpful thread from our very own Meg's guru Michael Stoops: http://www.meguiarsonline.com/forums...ht=chip+repair
The technique I use is very similar to his, but I've not used Dr. Color Chip or others. I've either used drops of actual matching paint I got from a paint guy using a very fine art brush, or when that ran out, a standard black paint pen which has a fine tip as well as clear. I tend to prefer the matching paint and brush method, as the paint pens can be very fiddly. The sanding afterward is not necessarily required, and the softer paint blobs will wear down over the course of continuing DA work over the months and years, but sanding helps blend and level the fill.
Re-Painting: You can spend $500 or less and have the worst spots "blended", a mobile service you can find through your dealer, or you can pay $3000 or more and have the entire car repainted. Either way, you can either have perfection or a hack job, and that's a whole other thread as well
Hope all that helps. My point is to do the correction as if the etchings and chips were not there, then take some pictures and time to think it over.
