Need Advice On Appropriate Backing Plate, Pads, Products
  • #16
    Re: Need Advice On Appropriate Backing Plate, Pads, Products
    Not sure why this is again about me, but whatever. Your implication that MF is aggressive-only is incorrect. With technique, I've found MF can be as gentle as any foam pad, but regardless of technique, not just any foam pad can be as aggressive as MF when it counts. Therefore, MF offers me the widest range of applications, soft to hard, gentle to aggressive. This is not controversial. Meguiar's DAMF marketing materials make the same or similar claims. If thin foam discs can approach that, great, but there are other reasons I prefer MF over foam, Detailer over Ultimate, and I'm not the first one to notice.
    As for cleaning foam pads, you can certainly wipe the pad off if that's what you mean, but getting the soaked-in or dried-in product requires washing. You yourself have said this as you've argued for buying lots of sets of foam pads. You can rinse the pad out, but if you don't dry it, it's still soaked up so much water and residue as to be a problem when it's put to the paint, so it really needs to be fully cleaned and dried, and that's not cleaning on the fly. However, I've generally just pushed through and done the whole car, as it's not the end of the world. The MF fibers just do not soak up product quite the same way, and a quick brush while the disc is spinning is quite enough to clear the pad.
    Your misinformation about carnauba-based finishing is frustrating, as we discuss this over and over, thread after thread. I've discovered, mostly from Meguiar's own materials and threads here on MOL, how to maintain a true show car carnauba finish, on a black daily driver, in the hot-n-humid Southeast, with really no more trouble than using sealants on light paints in the dry Southwest (or at least, if we were working in the same weather and had the same driving habits, the work for both finishes would be much the same). Sure, sealant protection might last longer all else equal for two cars sitting next to each other that never get washed or detailed, but all else is simply not equal and you know that. You and I are regularly wiping and boosting and washing and weathering the finish, etc. It's a totally moot point once maintenance starts. This is not a criticism of sealants, so there's no need to defend sealants against carnauba (sic). Indeed, to use your reasoning, carnauba was here first and has gotten the job done. In other words, the UW or NXT/M21 on your car will be wiped away and replaced, near enough as makes no difference, just as soon as my D301 or Gold Class, but you might not notice it, because the silvery glossy look is largely the same.
    As for what the OP or other new members want to try, that is their concern. People are free to make their own choices, of course. My goal here is to offer my lessons and insights based on my own experiences with foam, DAMF and carnauba-based finishing, particularly where they differ from what others are saying. I can maintain a black DD with D301 wax in a hot and often rainy, humid, and dusty climate. Someone out there might benefit from what I've figured out
    First Correction | Gallery
    • #17
      A couple of comments:
      - Any pad be it traditional foam, thin foam or MF can be made less or more aggressive by adjusting technique and product used;
      - You can indeed get the bulk of the excess product / spent paint out of foam by cleaning on the fly. Yes, to get foam properly clean will require washing, but that is also the case with MF pads.
      • #18
        BACKING PLATES:
        Meguiars Soft Buff DBP3 DA Polisher 3 Inch Backing Plate
        Meguiars Soft Buff DBP5 DA Polisher 5 Inch Backing Plate
        The Meguiars new DBP DA Polisher Backing Plates will fit all DA polishers with a 5/16 inch diameter shaft.
        Merlin
        https://AMiracleDetailing.com
        Facebook - YouTube - X - Instagram​​
        • #19
          Could you explain exactly what you mean by 'with technique'.
          I've given this some thought and believe I will in fact purchase some MF Pads. Not for my newer black vehicle, but to use - and learn - on an older vehicle.
          I still feel that as a first timer the foam pads might be a safer place to start, however as I learn - and have an old junker to practice on - I'd like to take advantage of the newer MF Pads as well. And learn exactly what the benefits of using MF are. Having both I'll be able to better understand the differences between them. (I'll be using the foam pads on the older vehicle to practice on first as well)
          Also,
          1. I've read M105 might be hard to work with. Should I avoid using this, and if so then what ? UC instead ? M101 ? D300 ?
          Given the photos and using flat thin 7/8" foam on a DA which would be the best compound to use ?
          Micheal Stoops: "M105 on a foam cutting disc may not really give you that much more cut than D300/DMC5 disc, but it will certainly give you a lot more dust and it won't be any where near as easy to wipe off in most cases".
          2. In using the MF Pads are there different compounds & waxes that should be used other than UC and UW ? More specific to MF Pads.
          3. What is meant by priming the pad ? Is this for foam, mf or both ? Compounds, waxes or all products ?
          Thanks again...
          • #20
            There are several areas where you with your technique will make all difference:
            • Machine Speed: Slower is generally less aggressive
            • Pressure on Surface: Lighter pressure will abrade less
            • Arm Speed: Faster is generally less aggressive
            • Pad Selection: MF varies by thickness, thinner is more aggressive
            • Pad Loading: More liquid can be more or less aggressive, depending on product
            • SMAT/DAT Abrasive: Working time can vary aggressiveness
            • Product Type: Is this a compound, polish, cleaner-wax, wax, sealant?
            • Repeated Passes: More is more
            So, using these basics, if you take the most aggressive and thin disc/pad (Xtra Cutting, "DMX"), at full speed on the machine, pressing down hard on the paint, moving the machine very slowly or barely at all, and then repeating with a good pad load, you will cut with the most aggression possible. Add a compound to that, and that's why there are so many "Nervous Nellie" comments on this forum. Yet, in my experience with my hard paint, even the above isn't aggressive enough.
            Likewise, at the other end of things, if you use the least aggressive disc/pad (Finishing Disc, "DMF"), at a very low speed, with very little weight/pressure, moving the machine faster across the surface, with little or no repeated passes, you will do little more than spread the liquid. This is a good way to lightly "clay" glass, for example, or spread a second wax, or work with a very soft paint. On a softer paint, you can use a milder compound and this Finishing Disc and be as gentle as any foam pad.
            I've given this some thought and believe I will in fact purchase some MF Pads. Not for my newer black vehicle, but to use - and learn - on an older vehicle. I still feel that as a first timer the foam pads might be a safer place to start, however as I learn - and have an old junker to practice on - I'd like to take advantage of the newer MF Pads as well. And learn exactly what the benefits of using MF are. Having both I'll be able to better understand the differences between them....
            That is an excellent approach. I think one thing you will have to learn first hand is that paint is not as delicate as we often fear. The first time I put a thick foam pad to my paint I was horrified to do damage. Now, I'm getting very aggressive with thin MF and sometimes barely making noticeable changes, unafraid of doing any damage, because I know that is nearly impossible.
            Dual-Action machines are great for most things, but they are not very aggressive, not like rotaries, and not like sand paper. That's the point. Most paint defects on contemporary paints look far worse than they really are, and so a DA machine is a relatively gentle way of fixing them, even with DAMF. For most purposes, the DA will be all you'd ever need, but sometimes you may have jump to the next level. In my case, a few careful strokes of sandpaper can solve the problem, then I use a Cutting Disc ("DMC") and D300 and the sanding marks/haze come out instantly, the original defect long gone.
            I considered getting thin foam as well as MF when I upgraded to DAMF, but as I've indicated, foam left me underwhelmed (not at first, but over time). The carefully worked out system of DAMF also appealed to me, compared to buying all kinds of products on "maybe". As it turned out, even the most aggressive methods with D300 or UC on MF were still not aggressive enough on my hard paint, so foam would have been a waste of money.
            1. I've read M105 might be hard to work with. Should I avoid using this, and if so then what ? UC instead ? M101 ? D300 ? Given the photos and using flat thin 7/8" foam on a DA which would be the best compound to use ?
            Well, those are more variables, and of course, quasi-religious questions There are people here who will defend M105 to the death, but I will never spend money on it because of what I've read here on MOL. Others will never be caught using UC, but I've found it to be near perfect both on foam and MF. With the DA, I've used ScratchX, D300 and UC - which are more aggressive in that order. Some defects like buffer trails and machine holograms can require many hours and repetition to master on hard paint, and I've even followed UC with D300 for further refinement, then followed with UP instead of D302, and then D301 is a cleaner-wax, so it has some small amount of aggression. In future, I plan to use M101 for heavy compounding, which should be noticeably more aggressive than UC, and even M105, but finishes like D300 and doesn't dust. This means I can fix defects faster, without having to do 12 or more pass/loads.
            With waxes and sealants, you can use any of them you care to try. With MF, I also got the liquids (D300, D302, D301) and I LOVE D301 even more than I previously loved Gold Class Liquid Wax. As I've seen different finishes on my black paint, already a glossy pearl-metallic, I've found I don't like the "Ultimate" line's silvery and glossy look (and on that note, Meguiar's has a few too many products branded as "Ultimate", IMHO). On my car, the silvery glossy look makes my black Coupe like some super-glossy plastic model instead of showing its true deep, rich, finish. Still, please use what YOU like, or try a couple of contrasting waxes to see what you might like in future. Again, these are almost like religious discussions I'm into the carnauba look.
            Priming is not usually something I've found to help. It's just loading product thoroughly into the pad so that it's essentially fully wet before touching the paint. This makes more of a mess, uses more product, can sling more product, much of which never sees the paint and only goes onto the ground or into the washing machine later. The Meg's videos usually show no priming, and many just show the reps doing an "X" pattern or 3 dots, etc. It really doesn't matter what the pattern is because the product will be spread well enough anyway. Where this makes a big difference is with wax, where even 3 small dots can be too much with some waxes.
            So, as you can tell from the discussion here and in other threads, many of us have different experiences and different likes. Some of these guys have been buying these products for many years and have a huge selection as well as more experience than I do. Yet, it's frustrating to read "just try this", or "this product should work", when I have to order it to find out (I'm still sitting on my decision to try M101 for that reason), so you have no real idea if it's going to work or be a waste of money. I'm just a guy working on my own cars who started with a DA less than 3 years ago, working by hand before that. I've also been on the web and in discussion forums for a long time, and I know what it's like to be less than trustful of what people say about products, more so today than ever before. Between marketing claims and other misinformation it's very difficult to know for sure.
            However, Meguiar's products really are what they say they are, the people who make them are right here on this forum, and the MOL regulars know what they're talking about. There are some variations in our approaches due to weather or paint hardness or carnauba finishing techniques, but I've learned to trust this forum. I say this not just for you, NYShine, but for anyone new reading this who's wondering about these same things
            • #21
              Also,
              I would not recommend M105 as your first compound. It will frustrate you. Ultimate Compound is a great compound. It's user friendly and a great starting point for someone new to this.
              Good article showing what ultimate compound can do.
              What do you do when presented with a black car that is just loaded, and we mean seriously loaded, with swirls? And scratches. And scuff marks. And haze. Yeah, basically just a black car with seriously messed up paint? Do you pull out the big guns? Or can you bring back a deep, rich, brilliant gloss using over the counter,
              M101 is a much better compound than M105. It has a longer working time. It will still dust but not as much as M105. I personally don't own M105 anymore now that I have M101 and D300.
              D300 was designed for the DAMF system. It works very well on with foam pads. Especially with the new thin Meguiar's foam pads.
              There is no best compound. Best is what works for you.
              D300 was designed for the DAMF system. Other compounds and polishes can be used with them. For example using M100, M101 or M105 with the microfiber cutting pads will be more aggressive than using it with D300. Those more aggressive products will also dust more. They are good when the defects are deep and the paint is hard. I have not used ultimate compound with the microfiber cutting pads.
              Another example are those Rupes owners who use the finishing disc with M205 to remove defects in a one step.
              Pad priming is an interesting topic. I do it the way Kevin Brown does it as depicted in this video. I believe it's around the 10 minute mark in the video. He's the guru when it comes to residue management.
              The issue with the X pattern is that when the DA is used, the product will travel to the center of the pad. With the X pattern a lot more product is concentrated on the center of the pad. Meaning your pads will load up quicker with spent product and of course more heat generated on the pad. There is also the circle method where a circle is placed on the outer edge of the pad which is a better way to go out of these two ways.
              The Kevin Brown method works and it's in my opinion the best way to prime a foam pad. Cleaning the pad on the fly every other panel or every panel helps with both foam and microfiber pads. A pad brush is nice to have. Compressed air is awesome on both types of pads.
              In regards to how to prime a microfiber pad everything is in this thread.
              Using Meguiar's D/A Microfiber Correction System - 2011 (https://meguiarsonline.com/forums/showthread.php?47855-Using-Meguiar-s-D-A-Microfiber-Correction-System) We are really excited to present our new DA Microfiber Correction System, a new concept in defect removal on factory cured paint. What's so new about it? This system,
              • #22
                Thanks again guys, as I said before your input and opinions are invaluable. And at 700 some hits for this thread others are hopefully finding it helpful as well.
                Anyway the pads arrived and I got to give it a go. I guess I have to say I am both very impressed and disappointed.
                Very impressed by how well the overall compounding came out, but disappointed that it didn't even touch the imperfections.
                At this point where do I go from here ? Is it a matter of repeated passes over time ? Move on to different products/techniques ?
                More pressure ? Slower passes.
                I used both an orange and yellow 5" LC thin 7/8" Pad, Mags 5" back Plate, a HF DA at settings 4 and 5 with UC and then afterwards even tried 105.
                Overall I just did the trunk as a test and spent approx one hour total.
                Here are a few photos... what you see here is just UC and 105, nothing more nothing less.
                Here's a nice shot of a cleaner section. Mirror finish !
                • #23
                  Compared to the first shots, it looks like a lot was cleared up, but based on your disappointment, it sounds like the second pictures are a bit deceptive? If so, yes, it will take more pass/loads (as I call them, loading product, working it in the pattern for at least 4 repeats, then reloading - that's a "pass" to me). I've done as many as a dozen or more of these sessions just for compound alone, then several of polish, then wax - but again, I'm talking about some very hard paint.
                  • #24
                    Go until the swirls are all gone, then proceed to the polish. No ammount of passes or product is going to remove those "spots" because there isn't any paint underneath to reveal. The only thing underneath those spots is bare metal.
                    I think it's coming along pretty good considering what it used to look like.
                    • #25
                      Sorry if this was mentioned before, but are those spots below the surface? They look like little rock chips or something, in which case you won't be able to remove them.
                      Regardless, it looks like its coming along pretty well. Do you think the light swirls in the first pic were already there, or could your relatively aggressive process have caused them?
                      • #26
                        Agree with this. Good job so far.
                        • #27
                          Oh no actually I'm very impressed especially that this was my first attempt. The car looks great and I haven't even gotten to the polish and wax yet.
                          I was disappointed though that it didn't affect the imperfections. But as others have pointed out they are chips and probably need a different approach (?)
                          Having watched many videos and seeing guys removing fairly deep imperfections I was hoping I would have had similar results. But being new I'm still not clear on what can and can not be accomplished.
                          Yes I believe you are right. They appear to be chips. There are water spots and tree sap etchings I haven't gotten to yet that are mainly on the hood, But in these latest photos (of only the trunk) most do appear to be chips.
                          I searched through MOL and came across this. Most seem impressed with the results and Michael Stoops even commented positively.
                          So after years of looking at this product and all my customers asking for a solution to "Road Rash" all over the front of their cars. I decided to get this system. I've done alot of single paint blobs and wet sanding and it's always a labor intensive job to get it right and usually the customer won't pay for the time
                          I wouldn't really go this route but the white chips/imperfections on black paint are all too obvious and really stand out. And now that the rest of the car is looking so good, those white imperfections actually stand out more and look worse believe it or not. LOL !
                          I'm just not sure exactly when to apply this. I'm assuming I should first finish the compound and polish phase, then try the Dr Color Chip. And lastly wax ?
                          Would that be correct ?
                          Sorry if this was mentioned before, but are those spots below the surface? They look like little rock chips or something, in which case you won't be able to remove them. Regardless, it looks like its coming along pretty well. Do you think the light swirls in the first pic were already there, or could your relatively aggressive process have caused them?
                          Yes they are in fact below the surface. My main concern were the etchings on the hood, but since I decided to start working on the trunk first I have a whole new set of imperfections to deal with.
                          As I mentioned to Eldorado I will probably try the Dr ColorChip or something similar. I think if this were a white car I wouldn't go that route but the contrast between the black paint and what seems to be white imperfections/chips really stands out.
                          The swirls I'm not sure about, but are probably my doing. I'm hoping that as I learn and improve my technique the results will improve as well.
                          Thanks. Yes the results so far are very impressive. These are excellent products.
                          As well the advice and opinions I received from those here were all equally excellent.
                          Thanks again....
                          • #28
                            Ah, I see. It was not obvious we were talking about two different sets of defects. The second shots almost seemed like the camera flash was making the previous etchings look worse than they were. I wonder if you can do a close-up macro shot of one of those chips like the excellent shots you got for the hood etchings? That would help.
                            Anyway, assuming these are true craters, either slightly lower than clear level or all the way down to the primer, there are professional options like "blending" which will cost a few hundred to fix. Or, you can fill them with various things on the market, and like on mine, black is very easy to match. The whiteness can be primer if deep, or contaminants if shallow. If shallow, then cleaning the spots and using clear alone might work. An inexpensive paint pen will have black and clear. This may also require some sandpaper techniques. Maybe those spots are not below the level of the surrounding clear, so the photos will help us give further advice, and there are threads on chip repair here that are easy to find. The shots above do not reveal any of these defects as unfixable with the DA, but it's hard for me to say.
                            Be careful of advice here or your own thinking that may sound like a defect is unfixable with the DA but just keep DA'ing indefinitely, more passes, etc. The spiderwebs on your paint seem to be coming out as expected, but the various spot issues will easily encourage you to keep on DA'ing when all you might be doing is removing more clear from large areas. Sometimes DA'ing really is a waste of time and energy, especially with foam, and a simple sheet of sandpaper on a tight spot will work wonders. That's a whole other discussion, as well as chip repair (search threads here for more), assuming these are true chips and not just superficial stains of some sort. Sometimes, a particular repair is beyond where we are at the moment, but can be fixed later when we get more experience (or more beer ).
                            • #29
                              If there's anything you need to be careful of, it's advice telling newbies to reach for the sandpaper. That's just fraught with danger IMO.
                              • #30
                                Yes that was my fault. I wasn't really understanding that there were actually multiple issues going on. Etchings, chips, swirls ect. As I mostly focused on the larger etchings.
                                I did more research and I believe I have what is termed 'road rash' along with the tree etchings and other assorted nasties. It seems to be a sort of catch all phrase for all those little chips and imperfections that I have on my hood and trunk. Here's a video dealing with a car that appears very similar to my situation with 'road rash' and how to address this issue. Of course with video and photos one can not really judge depth and type.
                                I believe most are chips of varying depth. I'll try to work on more photos. But these are very tiny compared to the etching photos I first posted.
                                Yes I will finish off the compounding phase then move on to deal with the chips. There is no point compounding any further as I removed all I can via compound/DA.
                                Here is a photo of the hood I took today. I have to say I think overall it came out very good for a first timer.
                                This is one pass with M105 and a yellow foam pad. Nothing more, nothing less. Quite a few of the imperfections are gone but the small 'white chips' are still there and very noticeable. They're just not showing up in the photo for whatever reason.
                                I just have one question though. What exactly did I do wrong here. I noticed this as I was finishing up.
                                The pad became concave. Can this be corrected ? I washed it by hand and it is drying so I'll see tomorrow if it returns to its normal flat position.
