Ultimate Polish
  • Ultimate Polish
    How hard is UP to work with been doing lots of reading and some say it's easy to work with some say it's hard to get off. Will be applying it by hand and am worried I'm going to get all kinds of marks and such. I was thinking maybe I should get the Adams polish that is made specially for hand applying but will it be compatible with the ULW i want to use and some say that wax is hard to get off. Getting confused Please help.
    Re: Ultimate Polish
    I think whatever you are using first is hard to get off. So, UC can be hard to get off if you use too much, then UP is easy, even if you use it liberally. However, UP used first is harder to get off than if following UC/Scratch-X. The "hard to get off" doesn't mean "marks", in my experience, but blotches of hazed product that seems frozen on (use some detailer to wipe it right off). I really love UP, though, as it's one of those best kept secrets
    First Correction | Gallery
      It's not hard to get off. Just don't allow it to dry on your paint before beginning to wipe it off. You'll get used to it in no time and realize any sort of complaints about it being hard to remove are no worries. Good luck!
        Re: Ultimate Polish
        Agreed.
          Re: Ultimate Polish
          Thanks for the replies. If you don't let it dry how long do you leave it on? Can tell i've never used this stuff. Is the Ultimate Liquid Wax the same senario?
            For the compound and polish, just put it on and wipe it off immediately. I know this sounds different from what you have heard in the past, but it is true.
            As for the wax, let it dry for 3-5 minutes. Remember more isn't better. A very thin layer will do the job. Think about applying wax. Only the parts that hit the paint are protecting the paint.
              After innitially priming your applicator pad either foam or microfiber applicator, [Do not use terry/cotton applicators as they tend to be too aggresive] dispense a small dime sized ammount of polish onto it and apply to a small section [12"x12"] of your paint using moderate Even pressure. You can do circular or straight line [back & forth] motions, which ever feels better for you. Just make sure to stay in your small section for each application in order to make overlapping passes with the polish.
              Staying within a small section while making overlapping passes prevents the polish from drying on the paint. Polish each 12"x12" section for about 30-45sec. or so... You want to polish long enough so that it's worked into the paint properly, aka "flashed". That will not only ensure you're getting the most out of it/using it properly, but it'll also make it quite easy to remove immediatly afterwards.
              However, you Do Not want to polish an area so long that you end up dry buffing. Because then you'll wind up like those people who you heard complaining about the polish being hard to remove.
              Hit that sweet spot right in the middle. Don't try to end your buffing cycle prematurely or you'll be wiping off goop.. But dont go so long that you end up dry buffing, or it'll be an actual hassle to wipe off. Once the polish Begins to thin aka flash, it's a good time to wipe off.
              Ultimate Liquid Wax is applied and removed totally different from the Ultimate Polish...
                Apply the wax with the soft foam applicator it comes with. Apply a nice Thin layer using no extra pressure other than to evenly cover all areas of the paint.
                A thin layer of wax is all that's needed. A thick layer will not do any better as all it does is lay on top of itself and make more to wipe off.
                It's usually ready to wipe off within 5-10min.
                When you wipe it off there's no need to apply any sort of added pressure as the job is already done. It should wipe off very smooth thanks to the thin layer you applied along with the clay/polishing you've already done.
                It won't wipe off so pleasurably if you apply a thick layer of wax. Good luck & have fun.
                  Re: Ultimate Polish
                  Check this thread out on how to apply ultimate wax.
                  We are proud to announce the 1st of several new Quik Tip Videos for 2011 ! After viewing the video clip you can scroll down for a step by step refresher, complete with still images shot during the filming of the video. <iframe title="YouTube video player" src="http://www.youtube.com/embed/RWE1s3dEHNk"
                    Re: Ultimate Polish
                    http://www.meguiarsonline.com/forums...-Cycle-Updated!
                      Re: Ultimate Polish
                      I will never use Ultimate Polish again. It was close to impossible to remove...no I did not let it dry. I have a bottle of the stuff on my bench, covered in dust, with probably a teaspoon gone. On the other hand, I love Ultimate Compound.
                      If you want to polish, try ColorX if you can find it, or Black Wax after UC. Both have close to the same polishing effect as UP, but are far easier to remove in my opinion, plus you get an added wax effect.
                        A couple of tips on using Ultimate Polish:
                        1. Shake bottle very thoroughly.
                        2. Sometimes it will "leave itself" on the paint. If that happens, place a super small amount of liquid on your pad, re-work the area, amd wipe it off.
                          Re: Ultimate Polish
                          Interesting... I've never had any problems removing UP.
                            Re: Ultimate Polish
                            Thanks guys for the replies I think I got it now.
                            1 question What do i use to wipe the ultimate polish off do I use a microfiber towel?
                              Re: Ultimate Polish
                              Yep. A clean, good quality MF towel.
