Re: NXT Tech Wax 2.0
Actually I mentioned and described the Swipe Test in my second point.
When MOL first started, Mike and I (I was the Super Moderator on here from day one and then for 4 more years, discovered that people were having issues with the set-up time. Hence the Swipe Test was established. And as I said, several factors contributed to this set-up/drying time.
Applying a wax thinly is difficult for some people especially on lighter colors. In time you will get the hang of it. Using a DA to apply a wax also makes applying a thin uniform coat easier.
NXT 2.0 is designed for paint. However, people sometimes use it for other surfaces. Just do not use it on your windshield as it can cause severe smearing when it rains. Wax on glass can also sometimes leave smears or cause a glare when the headlights hit the glass at night-time. They do make special glass polishes for glass. I use Pro Wax and Autoglym both of which do an awesome job. However, usually using a good glass cleaner like NXT Glass Cleaner is all one needs.
Originally posted by Tim Lingor
View Post
Originally posted by JTOWN
View Post
