paint rims?
  • paint rims?
    My rims look like ****. I might paint them black. any ideas on how to do it? Im gonna try to sand them a little bit to get an even surface and then paint them black....
    Re: paint rims?
    What kind of car is it?
    If you live around Charlotte, NC and would like your car detailed, PM me.
      Re: paint rims?
      what i did was take a wire brush attach o n a grinder. take off the paint. sand it with 80 -100 grit sand paper in teh cracks. hit it with primer. then paint them. hope this helps bro
      Click For My Main Youtube Channel
      Click For My Meguiars Review Channel
      ^^Meguiar's Review Specialist^^
        Re: paint rims?
        2008 Suzuki SX4 with 17' stock rims
          Re: paint rims?
          i told you how to do it?
            Re: paint rims?
            Have them powder coated
            www.rickspowdercoating.com/custom_cars_00030.htm
              Re: paint rims?
              Originally posted by Flash Gordon View Post
              too much money. Im on a budget...have to pay to get the car fixed first
                Re: paint rims?
                I agree with Flash; I would get them powder coated if you can swing it.
                If you need to paint them, there is a lot of prep work that needs to be done. You will need to remove old paint or sand down to at least 320 or 400 grit (perhaps get shot blasted), use spot filler putty to fill road rashes, sand again, prime with an appropriate primer (one that can handle high heat ie. brake cycles), and then wheel paint. You can do all of this (except shot blasting) at home! If you do not sand well enough or use the correct products, you will have only OK results. Do it once and do it right the first time!
                  Re: paint rims?
                  I would assume that the type of metal makes a difference. Otherwise it will come down to sanding, priming, painting, and then clear coat if desired. Just remember that the prep work will determine the results.
                    Re: paint rims?
                    Fix the car, and play later. Doing it right costs more than what it sounds like you have.
                      Re: paint rims?
                      Google is your friend
                      Just google "diy wheel refinishing"
                      That will get you tonnes of info
                      "STRIFE" aka Phil
