Spark Plugs - What's Running?
  • #16
    Re: Spark Plugs - What's Running?
    I'm currently running a set of Denso Iridiums in my PT Turbo, primarily because with the Stage 1 upgrade and a few other bits I'm running a fair amount more boost than stock. They are also one heat range cooler than stock. I also have Magnecor wires on that car.
    The Crossfire is running the same 12 (yep, 2 per cylinder) Bosch Platinums the factory put in it, along with the factory wires.
    • #17
      I have thought about running one cooler when I change mine.
      • #18
        The hemi's also have two per cylinder.. I dread changing the plugs in that engine.
        Although after looking at it it seems like they are fairly easy to get to..
        • #19
          Bosch Platinum + 4'S in the Impala. Just changed the originals at about 90,000 miles.
          Andy
          101impala
          Andy M. Moderator
          • #20
            Just remember that cooler plugs will foul quicker, so swap them out sooner than you would with stock heat range plugs. I ran one step colder on a 98 Firebird Formula I had and the plugs only lasted 13k before fouling out so much that it wouldn't rev beyond 5000 rpm (I thought my fuel pump was toast!)
            2018 Torch Red Corvette
            • #21
              Thanks for the heads-up!
              • #22
                I changed the plugs in 2 of my cars at 100K. No real problems but thought it was time to do them. One is a 98 Chevy Astro van and the other is a 01 Saturn L200. I got the plugs from Wal-Mart for both cars. They were Autolite and I think they were platinums.
                Try changing the plugs on a V6 Astro van! There was no way to do it from the top so I did them from under neath. Luckily there is quite a bit of room and I didn't even need to jack up the car. I had to stretch for some of them and had enough tools (sockets, u joints, extentions and ratchets) to get the job done with relative ease.
                • #23
                  AC RapidFires.
                  • #24
                    spark plugs? :P my engine runs on compression. who needs those dang things!!
                    02 Ford F250 Super Duty
                    International T444E 7.3L Diesel
                    Not exactly stock...laundry list of mods.
                    Straight Piped
                    PHP FU chip
                    • #25
                      NGK and Denso's are great
                      Matt
                      • #26
                        Agreed bout the NGK's. if its from japan its gotta be good.
                        Straight Piped
                        PHP FU chip
                        • #27
                          ngk coppers changed every few oil changes
                          • #28
                            No idea what I have
                            • #29
                              I run motorcraft plugs in the mustang.. Stock rating/etc
                              I run Autolite 104 coppers in the buick, 2 stages cooler than stock - and less chance of a hot point in the combustion chamber (IE less risk of detonation)
                              The Camry.. I'm not allowed to work on on my own, haha - It is a company vehicle
