Spark Plugs - What's Running?
  • Spark Plugs - What's Running?
    What spark plugs do you run in your car? I personally run Denso Iridiums with Denso wires.
    36
    Denso
    11.11%
    4
    NGK
    36.11%
    13
    Pulstar
    0.00%
    0
    Bosch
    13.89%
    5
    Nology
    0.00%
    0
    Autolite
    11.11%
    4
    AC Delco
    11.11%
    4
    Champion
    2.78%
    1
    Other
    13.89%
    5
    Re: Spark Plugs - What's Running?
    I'm kinda guessing that they're AC Delco on a new(er) GM vehicle. The engine compartment in my car (Cadillac STS V8) is shrouded to the point that all you can see is the dipstick so it may not have any plugs at all AFAIK
    Mort
      NGK Irids here.
      Probably a waste of money, but it make me sleep better at night!
      Boss_429
        Denso for me.
        SYDSTER
          Factory (Other) in the Roush, and the cheap Autolite Coppers in the truck.
            Whatever is on special!
              Came with NGK's
              They were alittle worn at 30k
              No wires for me! One coil per plug..
                I still have the factory ones with 50k miles. I was going to change them this fall but it looked too big of a job for me and I didn't have time. From BlueLibby04's post maybe I should change mine pretty soon. lol
                Scott
                  Same here...the Liberty has 37k on it now...can't imagine what they look like, but no problems from them so far.
                  Ryan
                    NGK iridiums in the Corvette and NGK G-power platinums in my wife's Honda.
                    I did notice a difference in throttle response on the Vette when I switched to NGK iridiums from NGK copper plugs. It was very slight, but definitely there. It seems to fire up a split second quicker on cold starts now too. (not that it took a long time before)
                    2018 Torch Red Corvette
                      Bosch Platinums in my F-150, probably go to NGK's when I change them
                      AeroCleanse, LLC
                      www.aerocleanse.com
                        Since two other Liberty owners posted in here, I want to say you need to make SURE you used compressed air to blow out from around the plugs before you take the plug out but after youve taken the coil off. I blew tons of sand and **** out which would of fallen down into the engine when the plug was taken out.
                        Check this thread that I made:
                        This was alittle more involved than I thought it was going to be. For one thing, having a lifted Jeep with bigger tires makes it a pain in the rear to work on anything in the engine bay. This was the first time working on it with the new tires on it and I can tell a big difference. Three on...
                          Yea...I might want to look at that considering almost all the off-roading we do is in the desert/dunes. I know how much sand comes out from the under body...I have the absolute worst luck with screwing things, honestly I strip almost everything I try to screw in, its a genetics thing or something. So I think I'll just take it to the dealer ship and have them mess it up...
                          Ryan
                            I have ac delco platinums in my caprice. They have been in at least 100k; Im going to do them this weekend.
                              Thanks BlueLibby! I emailed the link to myself, maybe I'll give it a go this winter.
                              Scott
