Is the Deep Crystal System Paint Cleaner safe
  • Is the Deep Crystal System Paint Cleaner safe
    I would just like to know if Deep Crystal System Paint Cleaner is safe on my paint. Am I damage my paint by using it.
    Re: Is the Deep Crystal System Paint Cleaner safe
    Hi Benzcowboy,
    Seeing this is your first post, Welcome to Meguiar's Online!
    The answer is no. Deep Crystal Paint Cleaner is a rich, lotion like product that is non-abrasive and safely cleans the surface of your car's paint using chemical cleaning agents. It is Meguiar's most gentle paint cleaner. The Deep Crystal System has been around since the 1980's so it has a long history of success.
    Wash your car first, then clay if you feel above surface bonded contaminants on the horizontal surfaces, then apply Meguiar's Deep Crystal Paint Cleaner using a clean, soft foam or microfiber over foam applicator pad.
    After applying, immediately remove using a clean, soft premium quality microfiber polishing cloth or 100% cotton towel. In the Meguiar's line, the only products that need to dry after applying are waxes; everything else can be wiped off after applying and working in.
    Hope this helps...
      I have used Deep Crystal Paint Cleaner tons of times and never had a problem. Works very well, easy to find and easy to use!
      Brandon
      2007 Black Chevy Avalanche
      My Albums: Avalanche
        I just finished using the deep crystal paint cleaner on my 2004 sebring it was worked great i would recomemend this product to anyone. great results
          It's a good product and safe. Give it a whirl with no worries.
          Bama
            I removed oxidation by hand with it a week ago. It worked great!
            Greg
            Pinnacle Detailing
              Thanks for the info
              Thanks for the info
                Tried the Paint Cleaner on the hood of my girlfriend´s red Daihatsu..
                It´s really great, the towel i used was practically pink after I was done..
                But one question.
                Applying the Paint Cleaner, can i use the cute small round yellow Meguiar´s foam pads? -or do i need to find something else?
                T-shirts are great, right?..
                Jørgen
                "Call me Joe"..
                1996´AUDI S6 AVANT QUATTRO
                  Actualy, a white sock turned inside out would work better than an old T-shirt.
                  The knap of the sock will help the cleaner work a bit better.
                    Originally posted by Murr1525
                    Actually, a white sock turned inside out would work better than an old T-shirt.
                    The nap of the sock will help the cleaner work a bit better.
                    Or a piece of terry cloth towel, basically anything cotton with a nap, (the little cotton loops). The nap will help to give your product more bit and thus more cleaning ability.
                      I find the Deep Crystal system gentle enough to use on my antique cars. I've never had a problem! Wonderful product.
                        can you use this product with a g100? or is it like scratch x where you have to apply in by hand.
                          I've used it for years with great results.
                          Kelly
                            The DC#1, and ScratchX, can be applied by machine, though I dont know if I would consider them the best product for the job.
                            If you want a very mild cleaner/polish with the G-100, then #82 may be a better choice ,as it is specifcaly formulated for use by machine. The cost of the #82 in bulk, and the cost of DC#1 may even out though since it is so cheap.
