I would just like to know if Deep Crystal System Paint Cleaner is safe on my paint. Am I damage my paint by using it.
Is the Deep Crystal System Paint Cleaner safe
Re: Is the Deep Crystal System Paint Cleaner safe
Seeing this is your first post, Welcome to Meguiar's Online!
The answer is no. Deep Crystal Paint Cleaner is a rich, lotion like product that is non-abrasive and safely cleans the surface of your car's paint using chemical cleaning agents. It is Meguiar's most gentle paint cleaner. The Deep Crystal System has been around since the 1980's so it has a long history of success.
Wash your car first, then clay if you feel above surface bonded contaminants on the horizontal surfaces, then apply Meguiar's Deep Crystal Paint Cleaner using a clean, soft foam or microfiber over foam applicator pad.
After applying, immediately remove using a clean, soft premium quality microfiber polishing cloth or 100% cotton towel. In the Meguiar's line, the only products that need to dry after applying are waxes; everything else can be wiped off after applying and working in.
Hope this helps...
I have used Deep Crystal Paint Cleaner tons of times and never had a problem. Works very well, easy to find and easy to use!Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
Tried the Paint Cleaner on the hood of my girlfriend´s red Daihatsu..
It´s really great, the towel i used was practically pink after I was done..
But one question.
Applying the Paint Cleaner, can i use the cute small round yellow Meguiar´s foam pads? -or do i need to find something else?
T-shirts are great, right?..
Jørgen
"Call me Joe"..Arctic Detailing - Northern Norway
1996´AUDI S6 AVANT QUATTRO
Originally posted by Murr1525
Actually, a white sock turned inside out would work better than an old T-shirt.
The nap of the sock will help the cleaner work a bit better.
Or a piece of terry cloth towel, basically anything cotton with a nap, (the little cotton loops). The nap will help to give your product more bit and thus more cleaning ability.
The DC#1, and ScratchX, can be applied by machine, though I dont know if I would consider them the best product for the job.
If you want a very mild cleaner/polish with the G-100, then #82 may be a better choice ,as it is specifcaly formulated for use by machine. The cost of the #82 in bulk, and the cost of DC#1 may even out though since it is so cheap.2017 Subaru WRX Premium - WR Blue
