After I have washed my car, dried it, and used UQD, I still have a little bit of water spots on the car. Any recommendations on removing them? I think they are below the surface :/. The car is not even a year old.
Removing water spots
Re: Removing water spots
Have you tried swirlx or ultimate compound by hand? If that dosent give you the results your looking for you might look into a buffer.Practice doesn't make perfect, the dedication to achieve perfection makes perfect. "Smack"
2011 Jet Black 328i Touring
2007 Jet Black 335i Sedan
Yes. Take swirlx and put a dime sized drop on an foam applicator and thoroughly work it into the surface. When it becomes a very thin film, wipe off with a microfiber towel and if needed, move the vehicle into the sun to check your results. A second application may be required. If after the second passwith little improvement, try and application of Ultimate compound.Practice doesn't make perfect, the dedication to achieve perfection makes perfect. "Smack"
