I was using APC diluted to 4:1 on my wheel wells the other day and just went ahead and sprayed the wheels and used a wheel brush on them and I have never seen them so shiny. I have been using megs hot rims. They are factory clear coated aluminum wheels. Is it safe to use apc on wheels and if so should I change the dilution to make it safe if it isnt already?
APC safe on wheels?
Re: APC safe on wheels?
I would want to go back to 8-10:1 as much as possible.
The only thing I am not sure about is if the lubrication is the same. I seem to recall hearing that the Hot Rims will have some lubrication to avoid scratching clear coats, etc like a soap would. Not sure if the APC will have that or not.2017 Subaru WRX Premium - WR Blue
APC should be safe for factory clear coated aluminum wheels.
I have been using APC+ (at 4:1 and 10:1 dilution) on my factory clear coated wheels without any problems for the past 2 years.Andy W.
Ford - '91 Ranger
Originally posted by ckylesworld View PostI was using APC diluted to 4:1 on my wheel wells the other day and just went ahead and sprayed the wheels and used a wheel brush on them and I have never seen them so shiny. I have been using megs hot rims. They are factory clear coated aluminum wheels. Is it safe to use apc on wheels and if so should I change the dilution to make it safe if it isnt already?
If you do use All Purpose Cleaner or APC+, agitation will provide the best results.
But you guys probably already new that.....Do it right the first time
Originally posted by Jeff Brown View PostIf you do use All Purpose Cleaner or APC+, agitation will provide the best results.
Originally posted by Bill Davidson View PostNot really. Some people expect APC and other products to work like caustic soda. I personally like the least aggressive approach Meguiar's takes with many of the products. Allowing the products to dwell a little bit, or a little bit of agitation is typically all that is required. Much better than using products that are potentially harmful (at least in my opinion). To me... the Detailer line strikes the perfect balance between safe and effective.
Have a good weekend everyoneDo it right the first time
