deep crystal and buffer
  • deep crystal and buffer
    Can the deep crystal steps 1 & 2 be applied with a
    Porter Cable dual action buffer. If so what type of pads
    would I need? I plan to finish the car with NXT.
    thanks
    Frank
    Yes, use the yellow polishing pad.
      .... then use the finishing pad with the NXT the tan one.
      Brandon
      2007 Black Chevy Avalanche
      My Albums: Avalanche
        I was thinking I had seen Mike maybe mention that the polishing pad was the best idea for NXT application?
        Mike?
        2018 Subaru Outback 3.6R Touring - Crystal White Pearl
          deep crystal & buffer
          Hi
          Thanks for the input!! I don't have the Meguiar pads. I purchased
          my buffer from Proper Auto Care and have their pads. They do have a reference chart and I have their pads that cross reference
          to the Meguiar pads. Hope to recieve my product on Monday
          and hope for good weather on the weekend of the 20th.
          I have been impressed by the comments about Meguiars products
          on the forums and the prices are reasonable compared to some
          of the other brands on the market.
          thanks
          frank
            I like to use the red cutting pad with DCPC myself...On the 5 setting.
            r. b.
              Hi
              One thing I fogot to ask, what speed do you recomend
              with the Porter cable dual action buffer for the deep crystal
              and for applying the NXT wax?
              Frank
                Re: deep crystal and buffer
                Originally posted by tasdisr
                Hi
                One thing I forgot to ask, what speed do you recommend
                Frank
                Hi Frank,
                For the Deep Crystal Step 1 Paint Cleaner and the Deep Crystal Step 2 Polish and the NXT Tech Wax, you can use a range of settings from the 2.0 to the 4.0, whatever feels more comfortable for you.
                For the paint cleaner, you should probably use the higher setting however for better cleaning action.
                  Re: Re: deep crystal and buffer
                  Hi Frank,
                  I agree with Mike...I find that using a setting of 5 on the PC will work the product in well...DCPC will not dry out too quickly, thus allowing you to work on a section for a good minute or two...But I don't buff it dry.
                  I like to spread the product out on 4 1/2 speed, then change the setting to 5...(This will help reduce the possibility of sling).
                  r. b.
