Hot Rims All Wheel Cleaner ~ Review
    Re: Hot Rims All Wheel Cleaner ~ Review
    No, OEM wheels are generally not powder coated - they're either chrome, polished aluminum with a clear coat, or fully painted. If you have aftermarket wheels you need to find out exactly what the surface material is in order to select the proper wheel cleaner. If your wheels have been refinished it's important to know that surface material as well.
    For factory supplied wheels our Hot Rims All Wheel Cleaner is perfectly safe. You need to be aware of aftermarket brake kits, however, as this product can sometimes stain different caliper finishes.
    For quality chrome wheels (and trust us, there are some really low quality aftermarket chrome wheels out there) our Hot Rims Chrome Wheel Cleaner is perfectly safe, but the same warnings regarding brake calipers applies. You might also want to steer away from this product if you have what are known as "chrome clad" wheels. These are actually a steel wheel with a chromed plastic covering bonded to the surface. Any damage to the edges of these covers can lead to issues.
    For all else, including bare high polished aluminum, powder coated, anodized (this usually includes "black chrome"), or magnesium wheels you should stick with our Hot Rims Aluminum Wheel Cleaner.
    If for some reason you are still completely in doubt, stick with good ol' soap and water. Use the same car wash solution you use to wash the rest of the car, just wash the wheels last and use a dedicated wheel cleaning mitt, sponge, etc.
      Ok thanks!
      ...these Wheel Cleaners, for some reason (abuse), can damage/burn the clear coat?
        Originally posted by Math87 View Post
        Ok thanks!
        I have not had any bad experiences with All Wheel/Aluminum/Multi piece wheel cleaners on paint. In fact, I use Eagle One All Wheel/Tire cleaner on my lower fenders to get the road grime off real quick and in a hurry. Of course this strips any wax. Remember, clear coated wheels are, well, paint. There are some Clear Powder Coated wheels out and about. Just be careful with them. Wheel Brightner is harsh stuff so be careful with that. Use soap and wash prior to using a wheel cleaner. When you use a wheel cleaner, it strips any wax you may have put on the wheel. I use soap first, then move up. Least aggressive first!
          If u guys don't mind me asking, where does the Gold Class All Wheel Cleaner fall in the mix as far as cleaning ability. I just got some for real cheap at my local Target.
          • #20
            Its around the same strength as the All Wheel Cleaner I believe.
            On a side note, for wheels with nasty brake dust on the face of the wheels & inside the barrels, I like to hose them down with water, spray on WB at 4:1, and then pressure wash. This really gets in the nooks & crannies of the wheel and also cleans the inside of the barrels easier to. Then I follow up with a soapy water agitation.
            • #21
              Another happy user of the purple bottle, here! Even got me girlfriend's fake chrome Grand Am wheels (mostly) clean... Now thats impressive!
              2011 F150 5.0L 4x4
