i had my car into the body shope for soem minor repairs but now its covered in overspray not really bad but you can feelit when you slide you hand on the body.i was wondering will the detailer clay take the over spay off? and its also on my glass can you use the clay on the glass?.
detailer clay bar
Clay by all means.
Here is a tip. I've been claying glass for years. It removes road film better than anything else I've found.Jim
My Gallery
Hi mopar,
I would let the body shop know about the overspray as a professional courtesy, I would also let them know that you're opting to fix it yourself but if they like they can pay for your supplies.
Then purchase all three of Meguiar's clay bars and a gallon of Last Touch or Final Detail and test each clay following Meguiar's philosophy of
Always use the least aggressive product to get the job done"
I wouldn't take it back for them to fix, chances are too good the person they delegate the job too won't put the care and effort into the job as much as you will.
I would also take some close-up pictures of the overspray if possible and post them here for before and after.
By the way, the 1947 Plymouth Coupe I used for a before and after had white paint overspray over the entire car, including glass, paint and trim. I used Meguiar's Quik Clay System and with a little time and elbow grease removed all of the overspray.
Thanks everyone for you input. Iwent out and bought the quick clay this morning. It worked amazeing took all the overspray off.
what an inprovement over the old quick clay system the clay bar is bigger and glided so easily over my paint. And it was at a really good cost 19 dollars compared to mothers a 24 dollars. Thanks meguiars!!!!!!! You to Mike.
