2-step polish and protect
  • 2-step polish and protect
    I currently do a 2-step using 205 then following it with 21. I'm looking for a polish that can remove more defects but still be used right before LSP. Any suggestions.
    www.JaxDetails.com
    www.facebook.com/DentsAndDetails
    I may be slow, but I do poor work.
    205 is a polish you can try a compound to remove defects try ultimate compound, or 105. Polish will just bring out the shine it does not have abrasives enough to remove paint defects like you want. 2 stage is normally a compound then followed by a polish.
      Re: 2-step polish and protect
      SwirlX will be a bit stronger than #205. If you really needed a boost, Ult. Compound would be even stronger, and finishes out good on many cars.
      You also could consider the Paint Reconditioning Cream. That is a stronger cleaner/wax, and a regular wax after wouldnt hurt.
      Or looking toward the MF system.
      What machines are you working with?
        My opinion is to use D300 follow with D301 or LSP.
          i use a cyclo, i just bought the new dewalt rotary with the responsive trigger and bale handle, but am not comfortable enough with it to use on a customers car. Does D151 have more corrective ability then 205?
          www.JaxDetails.com
            i looked at the D300 system, but it looks like they dont offer 4 inch disk.
            www.JaxDetails.com
              The Aggressiveness Order of SMAT Products - This might surprise you! Super Micro Abrasive Technology = SMAT From left to right, the most aggressive to the least aggressive SMAT products From the most to the least aggressive... M105 Ultra-Cut Compound/M95 Speed Cut Compound = The same in abrading power
                for these kind of jobs, i tend to use #205 or #83. Outcome is quite similar. On some paints, #83 cuts a little more.
                1996´AUDI S6 AVANT QUATTRO
