I currently do a 2-step using 205 then following it with 21. I'm looking for a polish that can remove more defects but still be used right before LSP. Any suggestions.
2-step polish and protect
Re: 2-step polish and protect
SwirlX will be a bit stronger than #205. If you really needed a boost, Ult. Compound would be even stronger, and finishes out good on many cars.
You also could consider the Paint Reconditioning Cream. That is a stronger cleaner/wax, and a regular wax after wouldnt hurt.
Or looking toward the MF system.
What machines are you working with?2017 Subaru WRX Premium - WR Blue
The Aggressiveness Order of SMAT Products - This might surprise you! Super Micro Abrasive Technology = SMAT From left to right, the most aggressive to the least aggressive SMAT products From the most to the least aggressive... M105 Ultra-Cut Compound/M95 Speed Cut Compound = The same in abrading power
for these kind of jobs, i tend to use #205 or #83. Outcome is quite similar. On some paints, #83 cuts a little more.Arctic Detailing - Northern Norway
1996´AUDI S6 AVANT QUATTRO
