Recently bought the whole microfiber buffing kit, including the cutting and finishing pads, backing pad, and D-300 & D-301. Bought the package so that I could get the backing pad, which Meguiars says is necessary when using the MF pads. Anyway, the results from the D-300 & D-301 are fantastic. The problem is that both the maroon cutting pads, as well as the backing pad disintegrated half way through the first car. Fortunately, the pad didn't fling away from the buffer, allowing the backing pad to damage the paint. It certainly looks like a function of heat, but I'm not sure what to do differently. The pad was primed per Kevin Brown's excellent instructions, plus the pad was blown out with 110 psig of compressed air after each panel to unload it of contamination. The pad (and paint surface) was checked for temperature before and after each panel and seemed fine. Has anyone else experienced this?
Thanks,
Bobby
Thanks,
Bobby
