M07 necessary?
  • M07 necessary?
    I tried using M07 on my hood after using M205 via G110v2. My paint is black, and pretty good condition. Applied TechWax 2.0 as LSP. It turned out great! Then I got curious...
    I wash my car again, then clayed. I use M205 with finishing pad @ speed 3, no pressure. I already know my paint is clean. But this time...NO M07. After the application and removal of TechWax 2.0, I did NOT notice any difference in shine, gloss or depth of my paint.
    Maybe M205 and TechWax 2.0 polishing oils, made up for M07's?
    Re: M07 necessary?
    Clear coats and newer paints just arent going to respond as much to polishing oils. So a new clear coat will be least.
    With some oils from the other products, you probably gave the paint all it could use.
      Re: M07 necessary?
      M205 has a pretty decent amount of polishing oils in it already, as does NXT Tech Wax 2.0, so in combination they should do a fantastic job for you. We've always said that use of a pure polish like M07 is an optional step, and that becomes even more so when dealing with a modern clear coat and/or when using a polish wax like NXT.
      On a clear coat finish that's in good shape, you'll probably notice more of a difference using M205 than you would with M07. This is due to the fine finishing abrasives in M205 and the level of clarity they can impart on the finish - something M07 can't do.
        Re: M07 necessary?
        Thanks guys! Now, it will take less time for me to do my paint right.
          Re: M07 necessary?
          Hello Ephios,
          Thanks for sharing this experience.
          It was very helpful to me.
            Re: M07 necessary?
            In my books polish like 07 is no longer required.
            Simply too much effort with little result.
            I switched to sealants instead, now that's something!
              Re: M07 necessary?
              M205 + TechWax 2.0 = Great Results!
              For me, M07 is too much effort to get little added result on my clear coat.
