M84 + Wool on rotary = Not enough
  • #31
    Re: M84 + Wool on rotary = Not enough
    Originally posted by AeroCleanse
    It's almost like the swirls / spider webs are there, then they cleared over it. I'm pretty sure that didn't happen, but thats the feeling I got.
    So after the M105 on the rotary, I hit it with M83 on a DA. The M83 didn't seem to change it at all.
    Must be harder than glass
    If everything you've tried so far is having little or no effect then it might be time to get a second opinion, is there anyone you now with years of polishing experience you could show this to?
    Is it possible to wet sand them out, or because its a OEM paint job is that ill advised?
    If you're not making a dent in the swirls that are already in the paint then it's going to be hard to remove sanding marks also. If the paint is truly the problem here, as in it just is not very polishable then it might be time to walk away from this project.
    Originally posted by 2hotford View Post
    I would give that a try and work smaller areas than normal.
    This is a good tip, just make sure you don't get the paint too hot, you should always be able to place the palm of your hand onto the surface without finding yourself jerking your hand away quickly because it's too hot.
    • #32
      Anyway we you can post some pictures in different light of what you are experiencing...
      This may also help diagnose the situation.
      Mike Pennington
      Meguiar's, Inc.
      800-854-8073
      mpennington@meguiars.com
