Meguiar's vs. 3M... metal polish!
  • Meguiar's vs. 3M... metal polish!
    This may be somewhat of a trivial comparison... but here's what I've noticed...
    Meguiar's:
    Good- Easy to apply, takes very little elbow grease to get good results, works on lots of dfferent metals, fairly inesxpensive (good value).
    Bad- Not quite as "bling bling" as it could be, leaves too much residue.
    3M:
    Good- Brings out every bit of nickel in the finish, giving it a BEAUTIFUL shine, adds a little wax to keep the shine lasting longer, residue is minimal, buffing is easy
    Bad- Price (at almost $30, it's f'n expensive!), mess (no matter what you touch, it'll have polish on it.), atrocious fumes, turns to concrete if left uncovered.
    These are just MY personal views... I like the Meguiar's, but the 3M seems to be a much better product.
    Vanity
    Automotive and Marine Detailing
    "Because when you want everyone to look at your car or boat's shine, that's Vanity."
    Re: Meguiar's vs. 3M... metal polish!
    Meguiar's:
    Good- Easy to apply, takes very little elbow grease to get good results, works on lots of different metals, fairly inexpensive (good value).
    Which Meguiar's metal polish are you using?
    I don't think I've ever seen a complaint about our new NXT All Metal Polysh, in fact only glowing reviews.
      3M:
      Meguiar's:
      I haven't heard of the new stuff.... wher can I get it? Is it better than the 3M stuff? I mean, I'd like to have my detailing bag 100% full of Meguiar's stuff, but the 3M metal polish has snaked its way in there.
      There's a few different metals I typically come across with the boats: Brass, chrome, stainless steel, and aluminum. Is this polish safe for all of them?
      Vanity
        Well, some of the Nxt products seem a bit tricky to find sometimes, but any Autozone, Advanced Auto sort of place could have them. Around here, all 4 Advanced Autos carry different parts of the Nxt Line.
          Give this a try,
          NXT Generationâ„¢ All Metal Polysh
          When it comes to polishing metals like aluminum, the goal is to producebrilliance, in the manner in which we're using the word brilliance, it means extreme brightness, we also want to produce clarity and shine. NXT All Metal Polysh produces extreme brilliance and also helps to lock the brilliance in by adding an anti-corrosive agent. Give it a try, I'm sure you will love it.
            hey mike i tried nxt all metal polysh this past weekend -- now of course i first cleaned my aluminum-alloy wheels -- dried them -- then i went to work on a section of one wheel -- after carefully reading the directions i applied the polysh -- worked it in really well -- then took a clean cotton cloth to buff -- unfortunately after i was done this section of my wheel didn't look any different from the rest of the wheel where i didn't apply nxt polysh -- now either i didn't do something quite right or the brilliant shine i am looking for has already been accomplished just through thorough wheel cleaning --
              Originally posted by a2z13
              hey mike i tried NXT all metal Polysh this past weekend -- now of course i first cleaned my aluminum-alloy wheels -- dried them -- then i went to work on a section of one wheel -- after carefully reading the directions i applied the Polysh -- worked it in really well -- then took a clean cotton cloth to buff -- unfortunately after i was done this section of my wheel didn't look any different from the rest of the wheel where i didn't apply NXT Polysh -- now either i didn't do something quite right or the brilliant shine i am looking for has already been accomplished just through thorough wheel cleaning --
              The only time I have never seen a metal polish work on aluminum is when the aluminum has been anodized. If aluminum is anodized, in order to polish it you must first have the anodizing removed.
              Do you know if your wheels have been anodized?
                can't say that i do --
                  And this stuff is recommended for marine use?
                  Vanity
                    You bet, the label says, All Metal Polysh, give it a try!
                      I tried some of the new nxt polysh on the polished wheels at the Meguiars "Fun Day" and it worked real well. Only problem is I can't find it in any of the local parts stores to purchase. I've been to pep boys, kragen, autozone, chief....nothing.
                      -Bob
                        Just a quick question... Did the polysh turn dark in color while you worked it in? If the polysh stayed the original color, your wheels are probably coated.
                        Good luck.
                          Does the NXT Polysh come in anything larger than the little tiny can it's in at the stores?
                          Yeah, it's fairly inexpensive, but it's a bit of a pain to have to buy a bunch of them at a time.
                          For what it's worth, I'll plow through a full can on just the handrail alone on some of the boats. Add another can for the rest of the boat, and you see where my problem lies.
                          This is one of the other reasons I use the 3M Marine Metal Restorer and Polish... it comes in a big fat 18 oz. can. I can do *ALMOST* 2 boats with one can.
                          Just figured I'd ask, from more of a "commercial" standpoint, i.e., someone who uses a LOT of it, EVERYDAY.
                          Vanity
                            This would be a great idea for the New Products Suggestions Forum
