Meguiar's Ultimate Iron Remover
  • Meguiar's Ultimate Iron Remover
    Meguiar's Ultimate Iron Remover - 2025 New Product
    Click image for larger version
    Meguiar’s? Ultimate Iron Remover quickly removes iron-based contaminants and industrial fallout, preparing the surface for compounding, polishing, waxing, or coating. This crucial step removes embedded below surface contaminates that reduce smoothness, color, clarity, while maximizing bonding for last step protection.
    Features:
    •Safe and effective contamination remover
    •Deep cleans paint before protection
    •Restores paint smoothness
    •Changes color as it cleans!
    •Essential to use prior to polishing or applying coatings
    •Pleasant smell
    Product Details:
    Part #: G250524
    Contents: 24 fl oz (710 mL)
    US MSRP: $12.99
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
    When will this product be available?
    The "pleasant smell", does that mean this is not thioglycolate-based? Or does it just have a fragrance added on top of the bad smell?
      Great extension to Ultimate line of products, which is super user friendly and high performance. It goes on my shopping list.
        Online in Mid December, starting in stores first of year.
        Regarding smell, not quite as simply as "adding a fragrance on top" but we have worked to dramatically reduce the smell.
        Nick Winn
        Irvine, CA
        nawinn@meguiars.com
          That sounds great!
            Is this "friendly" enough that it can be used for clay bar step, to remove above and below contaminants at same time?
              No, strictly for embedded iron contaminants. Will still need to clay after application, if needed, however, this will make the clay process much easier as you have removed any iron contaminants.
              Nick Winn
              Irvine, CA
              nawinn@meguiars.com
                Is it much different from the pro line version?
                  Hi arthuruscg,
                  Yes, our PRO D1801 Wheel & Paint Iron Decon does have several key differences compared to other options.
                  It’s specifically formulated for both paint and wheels, so its viscosity is adjusted to suit both application types. One standout feature is its pH-balanced degreasing component, which is particularly effective on wheels but also safe for paint. Being part of our PRO line, it’s available in larger sizes (1 gallon and 5 gallon), and it delivers a significantly higher level of active ingredients—making it more aggressive in performance. However, with that comes a notably stronger odor, which is something to keep in mind.
                  That said, Ultimate Iron Remover remains a very capable product. If you're ever unsure whether you've fully decontaminated a surface, we recommend simply applying a second round and checking if the paint still reacts (turns purple). You can also allow it to dwell longer—just be sure it doesn’t dry on the surface.
                  Ultimate Iron Remover offers a more consumer-friendly experience, especially in terms of odor, and comes at a lower investment compared to the PRO D1801. The team really focused on reducing the smell while maintaining solid performance.
                  Meguiar's Ultimate Iron Remover - 24 oz.
                  Meguiar's Wheel & Paint Iron Decon, D1801 - 1 gal.
                  Meguiar's Wheel & Paint Iron Decon, D1801 - 5 gal.
                  GHS Secondary Labels | Meguiar's
                  Meguiar's Generic Spray Bottle - 32 oz.
                  Meguiar's Chemical Resistant Sprayer
                  Nick Winn
                  Irvine, CA
                  nawinn@meguiars.com
