Black CTS-V, heavy paint correction and Opti-Guard coating
  • Black CTS-V, heavy paint correction and Opti-Guard coating
    The owner recently traded up his '05 CTS-V (which I detailed two years ago) for this used '06 model, and as you can see the paint needed a "little" love in order to bring it back to life.
    I had hopped to keep this job two a two step correction, however there were far to many deep RIDS which were taking too long to remove so I opted to bust out the rotary and wool pads.
    Correction Process:
    -M105 via rotary and Solo wool pad
    -M105 via DA and Meguiar's MF cutting pads (finished down very well)
    -106fa via DA and tangerine LC Hydro pads
    Coating Process:
    -Foam bath with OPC and CGCW to remove all polishing oils
    -IPA wipe-down
    -Opti-Coat(Guard) applied with supplied yellow foam applicator to all paint, wheels, trim, and lights. (8cc used)
    Before pics
    Brinkmann showing swirls
    Deep RIDS
    Very deep Scratch (too deep to safely remove 100%)
    Swirls under the halogens
    50/50 after M105 on rotary
    Gas cap fail!
    Polishing aggressively around gas doors can be tricky! By using some fine line 3M tape I'm able to protect the edges during the heavy compounding while still getting very close to them....much better than using 3/4" masking tape.
    This is after the first two steps....look how nicely M105 finished down on the MF pads!
    Wet sanding deep scratch (1500/3000)
    Not 100% gone, but hardly noticeable. (removed around 8-10 microns)
    Finished pics!
    Sorry, MN weather ***** lately and no sun shots could be had.
    Sun trying to find it's way out...
    Thanks for looking,
    Rasky
    Rasky's Auto Detailing
    Re: Black CTS-V, heavy paint correction and Opti-Guard coating
    That paint was thrashed and now it looks soaking wet. Amazing work Rasky.
      Looks great Rasky.
      Seems like the coatings are getting really popular now.
        Once again Chad....EXCELLENT-O!!
        Don
          Very nice Chad. That paint had definitely seen some better days and that day just came up. I'm thinking of giving my truck a coating. Still in the air though.
          Jesse
          www.ShineTechAutoDetail.com
          Facebook www.detailing.com
            Amazing turnaround Chad.
            2011 Jet Black 328i Touring
            2007 Jet Black 335i Sedan
              i like it
              proreflection
              *Ceramic Coating * Protection Film * Car Wrap * Paint Correction
              Detail Luxury and Exotics in Austin area
                That CTS-V looks incredible now!
                1976 Cutlass S
                2001 PT Cruiser
                1990 454SS
                1989
                Suburban
                  Sick work dude! Looks great.
                  Fergy-
                    Nice job Chad!
                    I love those Solo wool pads.
                    -Bob
                      Wow! the paint is so crisp and clear great work.
                      2008 Mazda CX-9 (WIFE'S)
                      1995 Ford F150 XLT (MINE)
                        Great job brining that paint back to life Chad!
                          Great work Rasky . Sorry to hijack your thread. Please can you offer some advise?
                          I have a Jag that I will be working on in a couple of days it has a rather deep scratch on the boot lid. I have not yet measured the paint thickness. Depending on what I find I will be able to cut 50% out with some 2500/3000 unigirt no problem.
                          When you get really deep scratches do you simply reduce or try and fill with CC let it cure then wet sand/polish?
                          Many Thanks in advance,
                          Rappy
                            Great save, Chad.
                            That paint really needed an immediate attention.
                            Did you use burgundy or yellow So1o pad with your rotary? Great results with M105/ MF cutting disc as well.
                              Thanks Mark!
                              Looks great Rasky.
                              Thanks Nick!
                              Indeed they are! Pretty much every car I do now is getting coated.
                              Thanks Don!
                              Thanks Jesse!
                              It makes washing easier and it keeps the car looking cleaner longer too!
                              Thank you!
                              Originally posted by Cosmin View Post
                              i like it
                              Thanks buddy! Looks like business has been doing well for you!
                              Thanks Joel!
                              Thank you!
                              Originally posted by RDVT4ME View Post
                              Nice job Chad!
                              Thanks Bob! I love them as well!
                              Thank you!
                              Thanks Marc!
                              Rappy
                              Thanks Rappy!
                              Unless they are a wide scratch, I usually just try and reduce their appearance and I really don't like to pushing it...even if I'm using a PTG. Better to live with the scratch then risking a strike through.
                              Unless you get a good paint match, I find touch ups often look worse.
                              Great save, Chad.
                              Thanks Greg!
                              I used the heavy cut (maroon) Solo pad.
