Per the directions, I applied Ultimate Quick Detailer to my immaculate brilliant black Grand Caravan, one panel at a time, using Meguiar's micro fiber cloths. Over several hours, the paint hazed up, and re-buffing didn't help. Finally, two days later, I washed and dried the van, but still had silicon looking blotches, here and there, which buffed off. Has anyone heard of Ultimate Quick Detailer turning to a haze, or where might I have gone wrong? Thanks.
Ultimate Quick Detailer Hazing....
Re: Ultimate Quick Detailer Hazing....
Originally posted by pcmark View PostPer the directions, I applied Ultimate Quick Detailer to my immaculate brilliant black Grand Caravan, one panel at a time, using Meguiar's micro fiber cloths. Over several hours, the paint hazed up, and re-buffing didn't help. Finally, two days later, I washed and dried the van, but still had silicon looking blotches, here and there, which buffed off. Has anyone heard of Ultimate Quick Detailer turning to a haze, or where might I have gone wrong? Thanks.Bill Poirier
West Seneca, NY 14224
The surface was totally clean and dry, in my garage, in 65-degree weather, with the last wax being NXT, applied about a month before, with three washes in-between. I, too, thought about re-applying the Ultimate QD to see if the result would be the same, but it turned into such a nightmare the first time, I wasn't going to try it again! I never had an issue with NXT Speed Detailer or any other product.2006 Chopped and Dropped Dodge Grand Caravan SXT
PCMark,
I've had this happen before on my black car, a light haze appeared after using the product. Can't tell you why or how this happened, but it was the middle of the summer time here and I pulled it out in the sun to heat the paint up then pulled it back into the garage, re-wiped and it cleared up.
Tom
I have used Last Touch Spray Detailer, Quik Detailer, NXT Speed Detailer and Ultimate Quik Detailer on my black Vette. I use #80, #7 Show Car Glaze to polish and #22 Hi-Tech Yellow Wax for protection. The best one for my regiment is the NXT Speed Detailer.
All of the other products leave a haze, but you have to look hard in the right sunlight to see it. I use all the other products for my other rides. I like them all, but NXT is for the Vette.
As a follow-up, Meguiar's Customer Service emailed me, confirming that hazing can occur if Ultimate Quick Detailer is applied in high humidity, so that explains it. Thanks.2006 Chopped and Dropped Dodge Grand Caravan SXT
