Trying to hep out a buddy but, is there anyway you can remove buffer swirls by hand? They are not bad at all.
Removing buffer swirl by hand?
Re: Removing buffer swirl by hand?
Sure, just use a paint cleaner and work small sections at a time.
After the paint cleaner, polish with a much less aggressive product to work the finish to more clear, higher gloss and then apply your choice of wax.
M105 works great for removing swirls and scratches faster than ScratchX and Deep Crystal Paint Cleaner but you have to buy a quart at a time.
You can also use ScratchX or DCPC but you will have to apply with more passion and probably more applications to achieve what M105 can do.
The key will be working small sections at a time, about a foot square, and then when you finish one section and move onto the next section be sure to overlap into the previous section a little.
Originally posted by Mike Phillips View PostIt's a new product, it uses new technology.
It's in the Professional Line, not the Consumer Line, you'll want to find a PBE store or order it online.
The usual foam applicator or terry cloth would be fine.
You likely would need more than one application, so doing the first one or two with terry and then following up with one or two applications by foam can work well if you need a bit more agressiveness.
You would work M105 just like ScratchX... apply to a small area, smear around, then begin to work in with a lot of passion. The car should almost be rocking on the springs. Work until the product is a greasy clear, then wipe off, inspect, repeat as needed/wanted.2017 Subaru WRX Premium - WR Blue
Originally posted by Murr1525 View PostThe usual foam applicator or terry cloth would be fine.
And just to add...
This article explains what you want to do...
(Also intended for everyone that will ever read this into the future!)
Originally posted by dfw View PostAnyone know or done this by hand?
Jason
Originally posted by Rico View PostHi Guys,
When using ScratchX is it common for the application pad to contain pigment/color?
Take Care
Rico
If you're working on a clear coat finish you might have a tinted clear.
If you don't have a tinted clear coat finish and you're pulling color that's a bad sign.
Usually the color coat under a clear coat is not shiny but flat so it would be noticeable to your eyes.
