does that mean it is a 240 volt machine...in the states 120v volt is house current and some have dedicated 220volt (or 240 volt i cant remember) for special appliances
Your experiences is not unlike most beginners with the rotary. Firstly, you need to keep the pad flat. If you angle the pad, it can cause buffer swirls and holograms in the paint. If you look at the paint in direct sunlight, you may see the buffing marks.
Secondly, here are a few posts that should be read to help a person new to the rotary:
I also suggest that you find an old hood from a body shop or junkyard to practice on (unless that is the purpose of the older vehicle you are using). That way you can try different speeds, products etc and see how they react. The main thing is be patient as it takes a long time to get the hang of using the rotary properly. But with persistence, you will thoroughly love what the rotary can do for the paint finish!!
I too, prefer tilting the rotary - especially when I use Lake Country's Variable Contact 7.5-inch pads.
That said, I like to use Meg's flat pads on horizontal surfaces like the roof, trunk, and most of the hood.
I wouldn't worry too much about holograms until I get to the final polishing step where I burnish the paint to a high gloss with a finishing pad (and a final polish like Menzerna FPII).
Sometimes, you can't avoid 'em. Resist the temptation to go back and remove them with the same product/pad combo you unintentionally created them with. Deal with them in the final polishing step.
when I put M #83 or #80 on the hood for example with 1000 rpm , I get rush and I try to pass and finish the buffing area as fast as possible because the polish dry to fast!! may be I finsh one area in just 20 second!! is that normal I don't feel it's enaugh.
v12, is your Makita having a 5/8" spindle thread size? If W-64 fits exactly onto your Makita, most probably it is different from the one made in Japan which we have - M14 or M16 spindle thread size.
