I just found this on Amazon. Admittedly I have not been on the site much over the past few months, but when did DeWalt debut this beauty?
I copied the specs and features from Amazon and bolded the features I felt were significant. Has anyone tried the DWP849X? Any input or reviews from Tim Lingor or Superior Shine?
This is one AWESOME rotary polisher! Looks like DeWalt may have closed the gap significantly with the Makita 9227c
DeWalt DWP849X
Product Description
From the Manufacturer
The DeWALT DWP849X 7-Inch/9-Inch Variable Speed Polisher has a powerful, 12.0-Amp, all ball-bearing construction motor for long life and durability. It has electronic control that maintains specified speed under load delivering the desired finish results. The conveniently located variable speed dial lets user set maximum speed from 0-600/3500 rpm for different materials and applications. It also has a variable speed trigger allows user to control speed from 0 to dialed maximum setting easily. It has heat-treated, precision-cut steel gears for smooth operation and external brush caps for easy servicing. The large spindle lock button allows for easy and quick backing plate changes. It also features a Wool Ingestion Shield that eliminates wool ingestion increasing tool life and reducing service costs and a non Mar Rubber Gear Case Cover that reduces surface imperfections and improves gripping surface. Includes Polisher, hook and loop backing pad bale and straight side handles.
Product Description
Includes bale and straight handle, a non marring rubber gear case cover, and rubber rear handle. Weight is ideal for all polishing applications @ 6.7lbs. This polisher has a 7" hook and loop backing pad.
DeWalt DWP849X
Item Dimensions | |
Weight: | 8 Pounds |
Length: | 22.20 inches |
Width: | 9 inches |
Height: | 4.50 inches |
Product Features
Product Description
Product Description
- Controlled finishing system with soft start
- Electronic controls specified speed under load
- Variable speed dial sets speed from 0-3500 rpm
- Variable speed trigger controls speed from 0- specified speed
- Wool ingestion shields on the air intake prolong the life of the motor by reducing wool ingestion
