Re: Glass Polishing by Machine - Defect Correction
Lake Country sells a glass polishing kit that comes with a backing plate, felt pads (heavy cutting) and abrasive impregnated foam pads (polishing) as well as a cerinum oxide abrasive.
I have had great luck with this kit, again the trick being technique.
FWIW, the heat will distort the plastic layer between the the inside and outside glass, not the glass itself. It is not really a concern on the side windows or the back windows.
However if you are polishing a convertible or a classic keep in mind that excessive pressure can actually cause the glass to shatter.
