Orbital & Rotary
  • Orbital & Rotary
    I have an old WEN Orbital thats been barely used and I plan on bringing it out of hibernation. I can't find many articles about using an Orbital.
    Are the principles behind using a Rotary the same as when using an Orbital?
    Re: Orbital & Rotary
    Here is some great reading
    Rotary vs DA Polisher vs Traditional Orbital Buffer
    Let us know if that helps.
    Mike Pennington
    Meguiar's, Inc.
    800-854-8073
    mpennington@meguiars.com
      Oh ok,
      Orbitals are good for applying waxes and polishes, but not for doing intensive paint correction, right?
        That is a great way to look at it.
        Paint correction should be left to D/A Polishers, or even rotary buffers in some cases. It all depends on how much correction you need to do and your ability.
        Mike Pennington
        Meguiar's, Inc.
        800-854-8073
          Thanks alot Mike
            I prefer rotary for eliminate deeper scratches and wet sanding marks.Orbital for wax, sealant or glaze.
            www.ozcarwash.ro
            Atelierul de cosmetica auto din Craiova
              Hey 240sx
              Mike's right but I've had some good luck using a 10'' orbital with a foam bonnet and some scratchx or another type cleaner with some soft clear's and single stage paint's.
              Give it a try, grab you some tape and do a test spot. YOU NEVER KNOW UNTIL YOU TRY!
              Post back with some before and after pics and process if you try it
