By the way, I appreciate you taking your time to help me out!
My first real experience with the Rotary
Originally posted by wetlook
Mike, surely you don't mean #80 Speed Glaze? From the Meg's video, it has some protectants and is actually recommended for newly painted surfaces. Did I remember it right?
Originally posted by NickJRE
What are holograms like that generally caused from?
When you bring a buffing pad, spinning under the action of a direct drive rotary buffer, the rotating pad and the chemical of your choice is touching the paint. Thus the potential exists to instill swirls and holograms.
Your job is to use all of your skills and abilities along with your choice of pad and product to reduce the potential to instill swirls and scratches.
Don't forget where the finish started at.
Ok it's making more sense to me now
So what would you recommend to remove the holograms?
A little background about the pad I used.. I feel it may be the source of the problem. I bought it from a Local Place, It was orange in color which to me that always usually means a cutting-light cutting pad. He swear it was not a cutting pad yet a polishing pad.
Do I try #80 speed glaze again with a Yellow Meguairs Polishing Pad via the Rotary or should I go to the PC? I'd really like to use the rotary again but i'm not sure if that is the proper way to go?
From Hot Topics
Read through this for process...
Switching from 3M to Meguiar's - Rotary Buffer Questions? (http://www.meguiarsonline.com/forums/showthread.php?t=6224) Hi there, well its me again guys, look i been using 3M products and they work good, i just use the Perfect-It II Rubbing compund and the swirl remover, but now i am interest on using Meguiar's and i found
READ through both of these to bring your understanding of what can, and what cannot be done with a rotary buffer...
Again... from Hot Topics
Need HELP! - How to avoid holograms? (http://meguiarsonline.com/forums/showthread.php?t=4929) Hi Tim & Mike... I just used the combo of #83 and Meg's W8006 with rotary buffer. I buffed it into powder with up and down and side passes. I set the Makita speed around 1400. The look under the roof is awesome, glossy and
How to avoid swirls and holograms? (http://meguiarsonline.com/forums/showthread.php?t=4966) Do you *always* get holograms with a rotary, even with a finishing pad and say #82 ? I was trying to attempt making a clear coated finish perfect using only a rotary, and I've almost concluded it can't be done and needs to be
Mike, I thank you!! This makes perfect sense and you know what the more I think about this it makes even more sense to me! Thanks for those threads they were a huge help so now critique this...
Since the hood is very bad here is my plan of attack,
#83 DACP on a Polishing Pad @ 1500 RPMs making extra sure not buff too dry.
#80 Speed Glaze on a Polishing pad @ 1500 RPMs (to clean up any marring left by #83)
#82 Swirl Free Polish on a Finishing Pad via PC at about 4-5
Finish with M21 or NXT
Re: My first real experience with the Rotary
I would skip #80 and go right to the PC with #82 and a POLISHING pad - you should be able to remove any marring the #83 and rotary left behind. To me the polishing pad is the best of both worlds - when used with a mild to light polish it doesn't marr, yet is still effective in cleaning up hazing/light hologramming.2003 White Diamond Cadillac Escalade with Weld Evo Forged 22's
The method which I prefer most is...
M83/W8006/RB
M82/W9006/RB
Pretty much perfect combi...
