Hello, Everyone!
I'm thinking about buying a new rotary polisher (replacing my Milwaukee) The two that caught my attention are:
Hitachi SP18VAH
Specifications
Max Watts Out 2,560
Wheel Diameter 7"
No-Load Speed 0-600/3,400 rpm
Spindle Thread 5/8-11"
Spindle Lock Yes
Electronic Speed Control Yes
Tool Length 10-19/32"
Tool Weight 6.2 lbs.
11 Amp motor, forcible power that supports a variety of applications
Three electronically controlled devices, constant speed control, soft start, and two-way variable speed controls located on both the trigger and dial for flexibility and control
Heat resistant bearing chamber and iron ball bearings to extend tool life and durability
Loop-handle design, for efficiency and comfort
6.2 lbs, lightweight design facilitates maneuverability and ease of use
Makita 9927CX3
Specifications
Sanding Disc 7"
Wool Bonnet 7"
No Load Speed 0-3,000 RPM
AMPS 10.0
Spindle Thread 5/8" - 11 UNC
Overall Length 18-1/2"
Net Weight 6.6 lbs.
Variable speed (0-3,000 RPM) with pre-set maximum speed dial, ideal for ultra slow polishing
Electronic speed control maintains constant speed under load
Pre-set speed setting dial (from 600-3,000 RPM) for maximum control
3 prong plug to prevent static electricity accumulation
Easily converts to a sander
Lock-on button for continuous use at one speed
Fast and powerful polishing for clearcoat finishes
my quesition is which one is recommended for comfort and overall proformance by the professionals? value? better in the long run? (no local dealer near me)
Thanks!
Hitachi SP18VAH
Specifications
Max Watts Out 2,560
Wheel Diameter 7"
Spindle Lock Yes
Makita 9927CX3
Specifications
Sanding Disc 7"
Wool Bonnet 7"
AMPS 10.0
Net Weight 6.6 lbs.
Thanks!
