Hitachi SP18VAH vs. Makita 9227CX3
  • Hitachi SP18VAH vs. Makita 9227CX3
    Hello, Everyone!
    I'm thinking about buying a new rotary polisher (replacing my Milwaukee) The two that caught my attention are:
    Hitachi SP18VAH
    Specifications
    Max Watts Out 2,560
    Wheel Diameter 7"
    No-Load Speed 0-600/3,400 rpm
    Spindle Thread 5/8-11"
    Spindle Lock Yes
    Electronic Speed Control Yes
    Tool Length 10-19/32"
    Tool Weight 6.2 lbs.
    11 Amp motor, forcible power that supports a variety of applications
    Three electronically controlled devices, constant speed control, soft start, and two-way variable speed controls located on both the trigger and dial for flexibility and control
    Heat resistant bearing chamber and iron ball bearings to extend tool life and durability
    Loop-handle design, for efficiency and comfort
    6.2 lbs, lightweight design facilitates maneuverability and ease of use
    Makita 9927CX3
    Specifications
    Sanding Disc 7"
    Wool Bonnet 7"
    No Load Speed 0-3,000 RPM
    AMPS 10.0
    Spindle Thread 5/8" - 11 UNC
    Overall Length 18-1/2"
    Net Weight 6.6 lbs.
    Variable speed (0-3,000 RPM) with pre-set maximum speed dial, ideal for ultra slow polishing
    Electronic speed control maintains constant speed under load
    Pre-set speed setting dial (from 600-3,000 RPM) for maximum control
    3 prong plug to prevent static electricity accumulation
    Easily converts to a sander
    Lock-on button for continuous use at one speed
    Fast and powerful polishing for clearcoat finishes
    my quesition is which one is recommended for comfort and overall proformance by the professionals? value? better in the long run? (no local dealer near me)
    Thanks!
    Hitachi, $95+shipping.
    Makita, $140+ + shipping, unless you find a good deal on ebay.
    No brainer to me
    I want 4" Softbuff pads!
      they're are both quality machines and if memory serves... mike has had his makita (not the same model, but same purpose) for close to 20 years! can't go wrong with either...
        ..and a 5 year warranty...
        ....and a 1 year warranty...
        No brainer to me
        Ditto!
        Quadruple Honda Owner
        Black cars are easy!
          Where are you guys seeing the Hitachi SP18VAH for $95.00?
          The only prices i'm finding is in the $170+ range
            Coastal Tool
