Re: DA Microfiber correction system - poor perfomance, no defect removal
Welcome to MOL, GrossmeisterB! Very recently, I upgraded from the thick foam pads and Ultimate and Gold Class products to the DAMF system, and I truly do have extremely hard black paint. I'm very pleased with DAMF. Here's the development thread: http://www.meguiarsonline.com/forums...-for-PC-7436SP
Now, the videos are a guide, not necessarily a literal recipe for every kitchen. As you get comfortable with the setup, don't be afraid to get more aggressive if you're not seeing results, or less, if you're getting them more easily.
However, the linked shot you first posted shows a very decent cut across the middle based on your description of one "pass", so if that's right, your paint must not be very hard at all, very soft. I couldn't possibly get that much correction with a single pass/load using the Cutting/D302 combo! Also, if you think you're getting pad separation from one "pass", I just don't know how. The MF pads are pretty tough. If I understand you, the second shot you posted is not yours, but an example shot of pad separation?? Fear not.
So, unless I've missed something, I'd say your paint is way softer than mine to get that much cut using non-abrasive D302 polish, even given the Cutting disc, at such low speed. Did I miss something? Perhaps if you use D300 Cutting Compound on the Cutting disc, you might have all the power you'll ever need on that paint for deeper defects with little effort. Follow with D302 on either disc, then the Finishing/D301, of course.
To give you an idea of how much harder my paint is, using a Porter Cable I've had to go to full speed with heavy pressure using an Xtra Cut disc with D300, and I've STILL had to do many series of passes/loads to see depth of results you got in one pass of Cutting/D302. I've had to do as many as 8 sets/passes of product reload on some panels, just for cutting alone, and you got similar results with one pass of polish?? I wouldn't complain. Here's the hard paint combo I've settled on, generally, for a full correction (which I don't recommend for yours):
- MF Xtra Cut/D300, Speed 5-6/max, 4-8 passes/loads as needed
- MF Cutting/D302, Speed 4-5, slower passes as needed
- MF Finishing/D301, Speed 3-4, slow application
(~15-20 hours of work)
Based on the OP photo and your description, I'd say you won't need to work that hard by a long shot! Consequently, it looks like you need to be a lot more careful than I do.
I'll also say, be sure to adjust the speed and pressure so that the pad is oscillating and rotating as smoothly as possible without bouncing or vibrating wildly, and slow arm movement is best, very slow for polishing. You may be able to get away without any compounding, but I'd get some D300 just to make it easier and to get a good clean cut. You should be able to correct a small car like the Elise in 4 hours or less, by comparison.
