da microfiber didn't cut it, try m105 next?
  • da microfiber didn't cut it, try m105 next?
    My corvette has awful acid rain etching and very hard paint. I used the microfiber cutting pad and compound and worked it thoroughly with my PC. I worked a small test area on speed setting 5 and 6 with a good amount of pressure. Some of the spots are a bit less noticeable but I will need something more aggressive...is m105 with a soft buff cutting pad the next logical choice? I have a feeling that if the microfiber system couldn't cut it, then the etching may be too much for the DA. Thoughts? Thanks in advance.
    Re: da microfiber didn't cut it, try m105 next?
    For more cut I use 2 drops of 300 (keeps the dust down) and 2 drops 105 on a microfiber correction disc primed with 300. If that doesn't work the next step would be 105 with a wool pad and a rotary.
      I used MF and D300 on this Vett last week with no problems.
      I can come look at it if you'd like. I'm in RSM
      http://www.meguiarsonline.com/forums...ted!&highlight=
      DetailingByM.com
        Thanks bob, I'll give that a try. If rotary is needed, I'd imagine that the da300 would be suitable to remove any haziness from the wool pad/105.
          PWMD, I'm out of town this week, but I may swing by when I get back. Thank you.
            ^^^^ Ok great. click my link for my info
            DetailingByM.com
              Yes, I use the 300 and DA after the wool pad/rotary. I rarely use a foam pad because the wool pad cuts better and the 300/DA will clean it up just fine.
                a wool pad will leave micro scratches/buffer marks.
                These need to be polished out in order to get a flat reflective surface.
                <----- take a closer look at my avatar.
                haze needs a lighter polish to remove that. as in M205 or even a cleaner wax will sometimes remove haze.
                Foam and wool are two different pieces of hardware.
                I can cut a car pretty good with a Burgundy pad and M105.
                A wool pad on a rotary is an advanced skill. So foam on a DA polisher is a safer way to achieve the same results.
                and you use D300 with a DA and what kind of pad?
                DetailingByM.com
                  I see pulling out the rotary as a fairly drastic step (I've haven't used mine more that a couple of times times in the last few months). I almost exclusively use 300D, and 105 with a microfiber pad with the Meguiar's DA. Do you think the foam pad on the DA cuts significantly better than the microfiber? Also, why would I use 205 instead of 300D? It seems to me that while 300D may cut slower than other products in the end you get the same result with less risk, and less time wiping off and cleaning up after.
                    MF pads are closer to a wool pad then foam.D300 is apowerfull compound and M205 is a lighter polishing compound.I cut with D300 and a MF pad then follow it up with M205 if needed. Use what works for you. I can't tell you what you need to do I can only advise on what I've done and offer suggestions.All paint is different.
                    DetailingByM.com
                      Speed 5 and 6 seem awfully high for what you are trying to achieve. I have sometimes seem greater cut and progress as speed 3-4 than 4-5.
                      Also when using the MF pads are you doing the proper brushing or blowing between passes? Using minimal amounts of product?
                      I too am a fan of the D300 and M105 combo. M101 and DAMF have actually become my new go to. Still can;t get over the smell of M101 but the leveling and finish it leaves are beyond what I thought I would ever accomplish. Also not that it is always dependent are you using the correct sized pads...smaller pads will have more cut because of the increase pressure per sq. in.
                        So, are you finishing with D301?
                        I am using D300 then D301 as my normal workflow. for deep defects, bad water spots, etc. depending on severity I use D300+105 with MF Disk; or M105 alone with MF Disk; or 105 with a wool pad. If I use 105 with MF or wool pad I always finish up with D300 then D301.
                        Are you using 205 in place of D301 because you are protecting with a different wax/sealant, or is it a haze issue that the D301 isn't working on.
                        BTW, thanks for the conversation. It's really cool to get a window in to how other people approach things.
