Queation about counterweights and Backing plates
  • Queation about counterweights and Backing plates
    Hello Everybody
    I was thinking about buying a Meguiars DA Backing Plate and some Soft buff 2.0 pads. The backing plate is 5.75 inches so should I also buy a 6" counter weight or will I be fine with the 5" counter weight.
    Any Input will be greatly appreciated, Thanks
    Re: Queation about counterweights and Backing plates
    Originally posted by Ravi_1992 View Post
    Hello Everybody
    I asked this question before and Megs replied that they had a bunch of guys try two polishers one with the 5" counterweight and one with the 6" counterweight and they couldn't tell the difference.
    Now with that being said if you are sanding or working at speed 6 maybe you would feel more vibrations.
    I dug up this old thread for you Ravi.
    The Dual Action Counterweight 'Controversy' (http://meguiarsonline.com/forums/showthread.php?t=3330) I have one DA in our shop that is a few years old. It was supplied with a 6" counterweight to replace the standard 5". The theory being that the 6" lessens vibration when using 6" pads. So I just
      Thanks a lot for the quick reply Bill! I guess I should be fine with out another counter weight
        Unless you end up doing mass production and you get super picky with your tools in which case you'll likely be using rotaries 95% of the time, I'm sure you'll be just fine.
        and you're welcome.
        You said you weren't going to spend any more money
          What can I do , Its an addiction
            I understand, you're still getting set up though and you're almost there. This stuff will pay for itself, soon you'll only be buying refills and try a new thing here and there.
            Now when you start buy $200 waxes, you already have a shelf full of them and you're hiding them from your wife, that's an addiction
