W8006 pad came apart
  • W8006 pad came apart
    I was polishing a car today with a W8006 pad on my PC and I noticed the foam part of the pad was separating from the velcro part. I was just curious if there were any ideas as to what I did wrong or what happened that would make it fall apart? I have never gone over speed 5 on my PC, it wasn't very hot today (~75 degrees), I haven't even used the pad too much....not quite 10 hours of polishing with it yet. Any ideas??
    Re: W8006 pad came apart
    Is the backing coming apart from the foam or are you cutting into the foam with the backing plate on the PC? It's normal to cut into the foam with a backing plate since the backing on the pad is usually smaller than the backing plates used with the machine.
    Ivan Rajic - LUSTR Auto Detail
    Chicago, Illinois
    Recognized as One of the Top Nine Auto Detailers in the US by AutoWeek Magazine!!
      Did you wash your pads with water? If so this could be a contributing factor to the glue on the velcro failing. If not, when did you purchase the pad? Maybe you should contact customer service.
      Andy
      101impala
      Andy M. Moderator
        Call Customer Care, they can help you...
        In your sig line...
        Striking Details (future business name?)
        Can you purchase www.strikingdetails.com
        Find out and purchase if you want here, www.GoDaddy.com
        If so the go for it, if not then consider a name that also works as a domain name.
          Just wanted to update on the pad situation.....talked to customer care and explained how it didn't look like I had done anything wrong to misuse the pad and they are sending me 2 free ones. All the stories I've heard about outstanding Meg's customer care are true....I can say that from my own experience now!!
              Another happy camper. Just another reason why Meguiars is so good.
                Just a another question on this matter. Since Megs came out with the new pads, will they still be producing the old ones for all of us that have the old backing plates and pads?
                Remove swirls my friends.
                  Yes, the W7006, W8006 and W9006 pads will remain. You can use the new W7207, W8207 and W9207 with your current backing plate though so if you want to try the new pads you do not need a new backing plate.
                    I had this same problem today with my w8006 it just ripped in half while i was using it and i was my second use of it. So should I just call CS and see what they say?
                    Thoryamaha919 AKA Evan
                      You got it!
