Advice Needed: Hazy/Cloudy Headlights
    Re: Advice Needed: Hazy/Cloudy Headlights
    Step 1. clean area
    Step 2. mask off surounding area with tape
    Step 3. wet sand 1000 grit
    Step 4. wet sand 3000 grit
    Step 5. apply ultra compound using wool pad on rotary buffer (1800 rpm)
    Step 6. apply choice of polish using polishing pad on rotary (1500 rpm)
    Step 7. apply wax of choice, by application of choice (hand or machine)
    Step 8. sit back and stare
    www.firstclassmobiledetailing.com
      You sure you didn't buy a NEW headlight? That looks phenomenal!
      LOL I didn't. If you look close enough (or if I were to take some macro photos) you can still see scratch marks that are deep into the headlight.
        So what was your final process that accomplished those results? Nice job, btw!
          hi guys, first post here. was following the process on how to polish plastics. i got a fuel lid that is made of plastic and am trying to polish that.
          however after wetsanding with 2000 grit, there are scratch marks all over, and application of PlastX by hand does not remove them (and does not return the plastic back to its original shine)
          Is it because i did not use enough force to apply PlastX just like neo_phase?
          • #20
            Well done,you did a really good bit of buffing there.i'll need to do one of my front indicators soon,so,I atleast I picked up a few pointers here.
            Thanks...
