okay to use UP?
  • okay to use UP?
    Is it okay to use ultimate protectant on engine plastics? I have that and ASD but it seems nearly everyone uses hyperdressing instead.
    Re: okay to use UP?
    I'm really not sure to be honest. I use Hyperdressing as well. I dont think ASD would be a good choice since its solivent based and that MAY cause fire hazards (i dont KNOW this but for me it would be a concern).
    HD is waterbased so i can just basically spray the whole damn engine area and let it land where it may. Then i just let it set for a few minutes, start the engine for a few minutes after that and let the heat help everythign dry, then just use a MF cloth (old one) to wipe up excess dressing and i'm all set
    Here's a write up I did with pics etc. I've only done a couple engines but they turned out great and the method was very simple. Hope this helps: http://www.autogeekonline.net/forum/...rd-taurus.html
    Wills Amstutz
    Windows And Wheels Auto Detailing LLC
    www.WindowsAndWheels.com
    'Like' Us On Facebook
      Re: okay to use UP?
      I am not sure on this. I do not believe it was intended to use for engine.
        Re: okay to use UP?
        Well, UP is water based at least, so could be an improvement over ASD.
          Re: okay to use UP?
          When the engine bay is not that dirty, a lot of people just spray the dressing on all the plastic parts and leave it to dry. Since you can't spray UP, I would think the convenience factor would come into play for that reason. Otherwise, if you apply it directly to the engine parts, as to effectiveness or safety, that I don't know.
            Re: okay to use UP?
            Looks like I may have to invest in some HD! I'm also concerned about a fire hazard with the ASD. I also wonder if HD may be more tollerant of high temps found in the engine compartment. Convience isn't teally an issue anymore- I'm going to c lay and wax the compartment anyway.
              Re: okay to use UP?
              Ultimate Protectant can be used on plastics in the engine bay without issue. On some of the larger pieces it's easy enough to apply it lightly (ie, properly) and get a great appearance that won't attract dust.
              Of course, the "spray it and walk away" convenience of Hyper Dressing is what makes that product so popular for engine bay dressing. UP is just packed in such a way that you can't really do this.
                Re: okay to use UP?
                Good to know. Thanks, Mike.
                  Re: okay to use UP?
                  Thanks! The UP is one of my fave products!
                    Re: okay to use UP?
                    +1 here
                      Re: okay to use UP?
                      What type of consistancy is UP? Does it come in a decent bottle that makes it pretty easy to apply?
                      Wills Amstutz
                        Re: okay to use UP?
                        More of a gel/lotion kind of thing, in a squeeze bottle.
                          Re: okay to use UP?
                          This should help. It is lotion-like and comes in a squeeze bottle. As the above thread shows, it applies more like a wax than a typical protectant, sparingly in repetitive motions with a foam applicator.
                            Re: okay to use UP?
                            Originally posted by Mary S View Post
                            http://meguiarsonline.com/forums/showthread.php?t=40559
                            Good thread, and great results too. Thanks Mary.
                            Wills Amstutz
                              Re: okay to use UP?
                              I applied UP on under hood plastic components with great results. The dry film holds up well and does not attract dust like other protectants. I have been using UP since it hit the shelves last year and have fallen in love with this stuff. I even used it on the vinyl covered railing on my deck with awsome results and am considering trying it on the vinyl window frames on the house.
