i have got some serious dirt(HELP!)
  • i have got some serious dirt(HELP!)
    It was a one owner, an old lady. So i suspect the engine bay has never been cleaned. I have absolutely NO experience in cleaning under the hood.
    Surely a few neat-freaks around here can educate me.
    Daily - 09 Chevrolet Colorado - Techno gray metallic
    baby - 92 Chevrolet Caprice Classic - aged, yellowed, white.
    Re: i have got some serious dirt(HELP!)
    Two of mine with the steps and products:
    Total Time: 20 Minutes Process/Products Used Sprayed the warm engine down liberally with APC+ diluted 10:1 Let it sit for 5 minutes [Scrub here if needed] Sprayed off really good Let the engine run for 5 minutes Soaked up any excess sitting water Sprayed Water Based Dressing undiluted over the entire engine bay, and let it sit
    I figured since the outside was clean, I should work on the engine a bit. I didn't go all out since I just wanted to get the initial cleaning done, and you will see what I mean. Here it is uncleaned. I have no idea the last time it was ever actually cleaned. :shocked1 I know, right!? The Process: Covered the Air
      yeah just be sure to cover up anything you dont want wet to be safe and dont use a hard stream of water, then following the steps roushstage2 posted it should turn out great
        You may find this article helpful: How to Safely Clean Your Engine Bay.
        I had good use with APC+ (diluted 8/1) as my degeaser, and CD-2 as my engine dressing.
        --Al Kimel
          First, since this is your first post. to Meguiar's Online!
          Second, who are you calling Neat-Freaks?!
          George Carlin
            yea, nothing a little APC can't handle!
            Fergy-
              Thanks for the help guys.
              I'm hoping you are all neat freaks on this forum. hehe
                That looks like it calls for Super Degreaser!
                  quick question.
                  I don't think I've seen any of the professional detail products in any stores. Do any major stores sell that specific line? Do I have to order off the site?
                    You can replace the professional/detailer line products with the consumer line products.
                      I thought APC was a professional product.
                      Anyways, last time I was at my local shops they had;
                      simple green, super clean, some purple stuff, and citrus based degreaser
                      I'd rather not use the citrus, for the paint's sake.
                        I have used Simple Green as well. Dilute 4oz. to 32oz. water for a medium duty dilution. No matter which APC you use (Super Clean and Purple Power are degreasers IIRC, not APCs), you have to watch getting it on the paint as it can strip wax.
                          It looks a lot like mine did...
                          But then I cleaned her up...
                          I used the degreaser in the purple bottle you find at Wal-Mart, AutoZone, etc., assortment of brushes (mostly used a toothbrush, though) and a lot of passion. About 1.5 hours and a misting of M40 later and it looked pretty darn good!
                          Colin
                            Scratch that dilution. Not sure why they changed it on the website, I just found the chart I saved (thought it was high). Medium dilution is 1 quart of water mixed with 1 oz. Simple Green.
                              Originally posted by dope92cc View Post
                              quick question.
                              It could be you're looking in the wrong kind of auto parts stores, (there's two kinds, one usually has a huge neon sign and is located on the main drag, this is a Hard Parts store and the other usually has a very small sign and is located in the industrial area or in an out of the way place, this is called a PBE store, PBE stands for Paint, Body & Equipment. It is the PBE store that is going to carry our Professional Line including our Professional Detailer's Line.
                              Remember, if you don't see the product you want but you see just one other Meguiar's product on the shelf, that means they can order it for you and usually have it the next day.
                              How to locate Meguiar's Professional and Detailer products in your hometown
                              The above article is actually in the How To Articles forum.
