Newbie with Detailing Questions
  • Newbie with Detailing Questions
    I am new to the forums.
    I have a 99 Silverado (NBS), Platinum that has just been recently totally repainted due to an accident. After the repaint, the body shop put a polish on it.
    I want to detail my ride right, so I have a few observations and questions:
    1) I know that I have to remove the polish with dawn before I use the claybar. How much dawn do I use per gallon of water?
    2) Then I use the claybar, correct?
    3) Then I wash again. Do I use dawn again?
    4) Since I have a new paintjob, do I need to use a cleaner like Scratch X? I do see some very minor scratches.
    5) Then I use a polish like Deep Crystal?
    6) Then I finish up with wax. Which wax should I use? I am confused because there is NXT Tech Spray; NXT Tech Paste and NXT Tech Wax. I would prefer to use one that does not leave any white residue on the black trim parts of my truck. Is there one of these that is better than another in that regard?
    It might help you to know that my ride is garage kept and not a daily rider.
    Thanks very much for your help.
    Autumn
    Re: Newbie with Detailing Questions
    Hi autumn,
    Seeing that this is your first post, Welcome to Meguiar's Online!
    1) I know that I have to remove the polish with dawn before I use the clay bar. How much dawn do I use per gallon of water?
    Wow! This sounds like the kind of mis-information a person reads on all the other discussion forums. Who told you this? Or what discussion forum did you read this mis-information on? It's completely untrue.
    Hang on a second for the rest of your questions...
      2) Then I use the clay bar, correct?
      Meguiar's teaches that you first Evaluate the finish. The results from your surface evaluation will guide you to the products and procedures you need to restore your car's finish to its original condition, or better.
      If you truck was just painted, it shouldn't need to be clayed, but it is very possible that dry spray, or overspray paint at the body shop could have drifted in the air and landed on the paint before your brought the truck home, so after washing your truck, draw the palm of your clean hand over the finish and feel for little bumps on the surface. If you discover them, this is an indicator that you need to clay your truck's finish. If the paint feels like it's as smooth as brand new glass, then you likely don't have to clay the finish.
      Remember, Evaluate then choose your products and process. This holds true for every surface and procedure.
      You don't have to wash after claying, just wipe the lubricant and any clay residue from the finish using a microfiber polishing cloth as you move around the car. Leave the Dawn in the kitchen and move up to a premium quality car wash, you'll be glad you did.
      4) Since I have a new paint job, do I need to use a cleaner like Scratch X? I do see some very minor scratches.
      A new paint job shouldn't have any scratches, if it does, you need to find out if they're toweling scratches from a careless employee using a tatty rag to wipe the finish, or if they are sanding marks leftover from any wet sanding process that were not completely removed. If the scratches are the latter, they may be to deep to tackle with ScratchX, that's why you need to find out where they came from. If the scratches are just light scuffs or scratches from handling or someone accidentally touching the finish in any way, then ScratchX may be the way to go, just remember ScratchX is not formulated for fresh paint, but cured paint, that is older than typically 30 days, check with your painter and ask him when it's safe to apply a wax. See how long he says to wait.
      Anytime you use a dedicated paint cleaner like ScratchX, it is a good idea to apply a pure polish although it's not mandatory, it's just that it will make the paint look great and if you're a car crazy enthusiasts, this is the kind of thing we do.
      Autumn
      Again, as I mentioned above, before applying a wax you need to check with your painter and ask him how long to wait before applying a wax to his fresh paint work.
      I'll post the 5-Step Paint Care Cycle below, please read it all the way through and then you will know more about taking care of your truck's paint than most people.
        There is a ton of great information in the Information Station forums.
        (Posted in the The Information Station)
        What's the difference between polish and wax?
        (Meguiar's 5-Step Paint Care Cycle)
        There is a lot of confusion about the difference between a polish, and a wax. Many companies are marketing waxes and paint protectants as polishes and glazes and the terms have become almost interchangeable.
        Professionals know there is a big difference.
        Meguiar's is a true polish manufacture. That is, unlike many of our competitors that can only offer you a few products for cars with cured paint, Meguiar's product range runs from the highest quality finishing papers in the industry, to state-of-the-art pure synthetic paint protectants, to everything in-between.
        Example: Most companies only offer the following products:
        * Car wash
        * Pre-wax cleaner
        * One or two waxes (usually some type of natural wax or polymer/silicone synthetic protectant)
        * Multi-surface vinyl protectant
        And sometimes one or more of the following:
        * Some type of wheel cleaner, leather treatment, or tire dressing.
        Because they offer such a limited selection, and often times don't even manufacture the products themselves, they really have no expertise when it comes to formulating complex products that professionals require as an intricate part of performing their job duties as skilled craftsman. This is why frequently you will see a product whose purpose is to protect the paint labeled as a polish.
        Instead of merely defining the difference between a polish and a wax, below you will find the Meguiar's 5-Step Paint Care Cycle and the products and procedures for each of the 5 steps.
        The 5-step paint care cycle outlines the 5 basic but important procedures and the accompanying products that enable you to restore and maintain a show car shine on your car's finish.
        Below are the 5 categories of products including pure polishes and cleaner/polishes as they are placed in the 5-step paint care cycle.
        The 5-Step Paint Care Cycle includes:
        Step-1 Washing
        Washing removes loose surface dirt and loose contaminants that have not yet bonded to the surface. All Meguiar's wash products are specially formulated to clean well without stripping wax protection or dulling and drying out all paint types. All Meguiar's washes also contain special conditioning agents that leave behind a slick, high gloss surface.
        Because most people wash their car more than any other procedure, it's important to use a car wash solution that is specifically formulated for the unique chemistry used to make modern clear coats. Above all, avoid using common dish washing detergents because these products are extremely harsh and tend to dull the finish down with each use. Dish soaps are also hard on other materials and components such as rubber, vinyl and plastics, remember, when you wash your car with dish soap everything is subjected to the dulling and drying effects high alkaline soaps cause to your vehicle.
        Step-2 Cleaning or Surface Prep
        Surface Prep includes both paint cleaning (not to be confused with the washing step), and claying the finish (with a clay bar). To help you accomplish these two steps, Meguiar's offers a number of safe but effective paint cleaners and an easy to use clay bar kit that includes everything you need to clay your car's finish.
        Paint Cleaners
        This includes highly specialized Compounds and Paint Cleaners, which utilize both microscopic and macroscopic diminishing abrasives? technology. Meguiar's has pioneered and led the industry in diminishing abrasive technology since 1901. Over the course of these many years, Meguiar's has developed more formulas than any other company for performing the delicate procedure of removing a defect in the paint, while at the same time, removing as little paint as humanly possible during the process.
        Meguiar's diminishing abrasive technology is one of Meguiar's most guarded secrets that is so highly sought after by our competitors and which completely separates us from the rest of the competition when you look at the results with your own two eyes. Our abrasive products, correctly used, leave the surface looking as though it were just polished, not as though it were just scoured with a compounded.
        Out of all the procedures in the 5-step paint care cycle, cleaning is the most important procedure because the results from your cleaning step will determine the end result for the polishing and protecting steps.
        "A surface won't go clear until it comes clean"
        It is vitally important that all bonded contaminants, surface imperfections, oxidation, pore-embedding stains, and built-up road grime, etc. first be removed in order to bring the finish to it's highest potential for clarity, gloss, depth and shine.
        Applying a wax, whether it's synthetic, natural or a blend of both, to a neglected surface that has not been properly cleaned and then polished, will merely act to seal or lock the contaminants to the finish, and will do nothing to improve, or remove the other defects and in most cases will only marginally improve gloss, shine and reflectivity.
        Clay Bar Technology
        Clay bar technology evolved as a natural reaction to the need that arose for a way to safely remove bonded contaminants from clear coat paints without resorting to traditional rubbing or polishing compounds and the resulting scratches caused by the sharp, hard abrasive typically used in these formulas.
        In the old days, if you found overspray or any type of unwanted substance on the hood, roof or deck lid of your car that washing didn't remove, you could simply go to the garage and grab any old compound, and together with a rag, you could quickly remove the offending contaminants. After that you could simply apply just about any companies wax and presto-chango, the problem was gone.
        Not so simple anymore.
        If your were to perform that same procedure to a modern clear coat today, you would see a horrible looking scratched-up mess everywhere you applied the compound, and the wax would do nothing to cover the scratches up.
        Enter the Clay bar
        Clay bars are non-abrasive bars of synthetic clay called Polyclay. They are somewhat like a high-tech version of Play-Doh?. They work in three easy steps:
        1) - First you mold the clay bar into a pancake-looking flat wafer
        2) - Second you lubricate the finish with a spray lubricant like Meguiar's Quik Detailer
        3) - Third you then rub the clay bar back and forth across the paint (somewhat like a bar of soap against your arm)
        That's it! You are now claying your car's finish. As you're doing this, the clay bar will grab onto, lift, and pullout the contaminants that have bonded to the surface of your finish.
        Generally speaking for most cars, only the horizontal surfaces need to be clayed, as it is the horizontal surfaces that contaminants tend to land on and if not removed within a reasonable period of time will then bond tightly to the surface. For extremely neglected vehicles, you can always evaluate the vertical surfaces and if need be, clay them too.
        One important thing to keep in mind, if a vehicle's finish has bonded contaminants, it is highly likely that it also has below surface defects, for example, pore-embedding stains. For this reason, Meguiar's recommends for best possible results, always use a paint cleaner after claying to insure the finish is clean both on top of the surface as well as below the surface.
        Step-3 Polishing
        Meguiar's offers two types of polishes, Cleaner Polishes and Pure Polishes. Cleaner Polishes are for removing very light or fine defects while restoring a crystal clear, smooth high gloss surface. Pure polishes are for finishes already in excellent condition and are for the purpose or creating brilliant high gloss with deep dark reflections.
        If you look in Webster's Dictionary under the word polish, one of the definitions they include reads like this:
        "A preparation that is used to produce gloss, and often color for the protection and decoration of a surface."
        This definition best describes Meguiar's Pure Polishes. Meguiar's pure polishes are designed to create brilliant high gloss while preparing the surface for the application of a protective coating. Meguiar's pure polishes accomplish this without the use of abrasives.
        Another definition found in Webster's Dictionary for polish is,
        "To make smooth and glossy by friction."
        This definition best describes Meguiar's Cleaner/Polishes. Meguiar's cleaner polishes are formulated to very gently abrade the surface with Meguiar's Diminishing Abrasive TM and Buffered Abrasive TM technology to remove the finest defects and create a perfectly smooth, high gloss finish.
        Depending on what type of paint you're working on, traditional paints like lacquers and enamels, or catalyzed clear coats, Meguiar's has the products specifically designed to work on both types of paints, not to mention many other surfaces such as plastics and polyester resins (Fiberglas Gel-coats).
        Meguiar's Trade Secret Polishing Oils
        The trade secret oils Meguiar's uses in both types of polishes are unique to the industry and to this day have never been surpassed for creating deep, dark reflections and brilliant high gloss by any of our competitors in over 100 years.
        The oils Meguiar's uses are also important in maintaining the original condition of the paint by filling in the naturally occurring microscopic pores and surface imperfections thus preventing detrimental substances and elements as simple as water, or worse, acid-rain, from entering into these pores and microscopic surface imperfections thus causing oxidation and chemical etching. These oils act to replace the original resins as they wear away through natural processes.
        When paint is new, it is the most impermeable it will ever be, this means it is a very smooth non-porous, continuous film. With age, exposure to the environment and micro-scratching caused by day-in, day-out wear and tear, your paint develops micro-fissures in the surface along with other defects. These micro-fissures and other defects act to make the continuous film or coating of paint more porous. As this happens, your car's finish becomes more vulnerable to corrosive elements that will attack and degrade your finish.
        Remember, waxes, synthetic or otherwise, are meant to be Sacrificial Barriers with the intended purpose sealing the surface, while blocking those things that would attack your paint, from coming into direct contact with the paint.
        "Waxes protect your finish by sacrificing themselves so that your paint doesn't have to"
        An analogy is your skin. In the same way you can clean, polish and protect your skin, you can clean, polish and protect your car's finish. Soap can be used to clean your skin and remove dirt from the pores. Skin lotions can be used to moisturize your skin, conditioning it and making it more clear and beautiful. Protection products like lotions used to protect hands from exposure to chemicals and UV protectants can be applied to help protect your skin from the things that would attack your skin if these harmful things could come into direct contact with your skin.
        While human skin and automotive paint are very different, the analogy is very similar. With Meguiar's, you can:
        * Wash your car's finish to remove unwanted and accumulated dirt contaminants
        * Clean your paint with our special paint cleaners and cleaner/polishes
        * Polish your paint with our pure polishes to create unequaled beauty
        * Protect your paint with our advanced paint protection products
        * Maintain your car's finish using our fast and easy to use maintenance products.
        The unique thing about Meguiar's highly specialized trade secret oils is their ability to restore and maintain the Optical Clarity of both single stage and clear coat paints in a way that waxes alone cannot match, (both natural and synthetic), the results of which are demonstrated in side-by-side comparisons.
        Step-4 Protecting
        Paint protection products (waxes by any other name), whether they are based on natural ingredients or synthetic ingredients (or a blend of both) provide a protective film, or Sacrificial Barrier (as mentioned above) against Mother Nature and other detrimental or corrosive substances. Without this sacrificial barrier, your finish is susceptible to attack at any time, as harmful or corrosive substances come into direct contact with the surface.
        This brings up the topic of Water Beading. While most people use the visual indicator of water beading on the surface to mean their finish is protected... it is actually only an indicator of High Surface Tension.
        High Surface Tension does not automatically mean the coating that has been applied is actually providing any real or meaningful protective characteristics.
        Meguiar's R & D department has decades of expertise in creating the most advanced polymer-based formula's made from state-of-the-art engineered synthetic polymers, which are able to evenly cross-link very tightly to the surface and offer real protection on a multitude of surfaces against a multitude of attacks. Our products can also achieve optimal cross-linking within 15 to 20 minutes after application allowing the excess product to be removed shortly thereafter.
        Some of Meguiar's polymer-based waxes include:
        Meguiar's NXT Generation Tech Wax
        #20 Polymer Sealant
        Medallion Premium Paint Protection
        Gold Class Clear Coat Car Wax
        Meguiar's Cleaner/Wax
        Marine Flagship
        Even our Spray Waxes contain high performance, engineered synthetic polymers, as do some of our Car Wash products.
        Besides acting as sacrificial barriers to protect the underlying surface, a premium wax can also increase the visual appearance of a finish. Many of Meguiar's waxes will not only provide better protection than the competition, but will also:
        * Increase optical clarity and distinction of image (D.O.I.)
        * Enhance and increase the reflective characteristics of medium to dark color finishes
        * Add shine and slickness
        * Create wet-looking gloss
        * Fill-in and hide swirls and scratches
        * Provide the most UV protection available
        * Offer water sheeting action, or water beading action (depending on the wax)
        Choosing the right wax for your finish and your unique circumstances is something our Surface Care Experts would love to help you determine. Just call our Customer Care Hotline and talk to a knowledgeable technician to help you make the right choice.
        Step-5 Maintaining
        Maintenance products, like our Quik Detailer, and our Quik Wax, allow you quickly clean your car and restore that just waxed look in just a matter of minutes... practically anywhere.
        Meguiar's Quik Detailer removes fresh contaminants before they have a chance to bond or etch into the surface.
        Meguiar's Quik Wax quickly and easily boosts your already existing wax protection while turning your finish dramatically darker and increasing shine and gloss.
        Meguiar's actually invented the concept of a mist and wipe product for consumers back in the early-80's with the introduction of their mist & wipe product called "Trigger Wash"
        As leaders and experts in the surface care industry, we have a history of creating new products, such as mist & wipe products like our Quik Detailer and M-34 Final Inspection to help our customers maintain and beautify their vehicles.
        In keeping with that history, we have just introduced a brand new spray wax that produces similar results as Meguiar's Quik Wax. It's actually a part of Meguiar's NXT Generation line of products based upon Meguiar's ESP Technology (Engineered Synthetic Polymers) and is a companion product to Meguiar's new NXT Tech Wax it's called NXT Spray Wax.
        Meguiar's 5-Step Paint Care Cycle clearly demonstrates there are 5 basic steps to professional and intelligent car care.
        Using the correct Meguiar's products and the right technique, you can remove scratches and swirls that have accumulated from years of neglect to successfully restore a flawless, show car finish as demonstrated here on a 1991 BMW E34 M5. The left side is untouched, while the right side has been professionally restored using all Meguiar's products.
        The 5-Step Paint Care Cycle enables you to understand exactly what a product is not just by the name on the label, but by the results the product accomplishes according to the 5 different groups of procedures outlined in the 5-Step Paint Care Cycle.
        If a product is labeled a polish, but in fact is used to protect the paint, then you know it's a wax or a paint protectant and not an actual polish in the true sense of the definition of the word.
        Here at Meguiar's we manufacture some very complex products, of which polishes and waxes are only a small portion of our complete line.
          Mike,
          WOW! Thanks for the very detailed response. I have a lot of reading to do. I should tell you that the paint job was done six months ago and is fully cured. The truck has been washed often since then. There are some overspray areas on my truck, so I will have to clay some areas. The very minor scratches are from touching areas that had dust or grime on them. The very reason I posted my questions was because I read so much confilicting information on other various posts. I needed to get set straight before I began detailing my truck. I will now read, in detail, your response. I know I will have more questions. I wanted to reply now to clear up a few things.
          Thanks again for all of your help.
          Autumn
            Alright, I think I have it figured out...or at least most of it.
            I already have: clay bar and lubricant;
            micro fiber towels/rags;
            truck with almost brand new paint
            My shopping list: NXT Generation Car Wash;
            Deep Crystal System Paint Cleaner;
            Deep Crystal System Polish;
            NXT Wax (here's where I need more help);
            Gold Class Trim Detailer
            Procedure: Wash truck with NXT Generation Car Wash. Clay bar areas that need improvement. Wipe with micro fiber rag. Use Deep Crystal System Paint Cleaner. Use Deep Crystal System Polish. Use NXT Wax, paste or liquid. Use Gold Class Trim detailer. Marvel at how good my ride now looks.
            Big Question: I am still confused about which wax to use. I plan on doing all by hand. Please tell me which NXT wax to use, paste or liquid??
            Autumn
              Autumn
              Hi Autumn,
              Looks like you are a quick study!
              Two things...
              If you have light scratches or scuffs, you might want to also add some ScratchX to your list as it really does offer the ability to remove light defects like these whereas the Deep Crystal Paint Cleaner is a chemical only paint cleaner and while it works great for what it's intended to do, it is also a very light cleaner.
              As far as wax choice goes...
              Liquid's tend to be easier to apply and wipe off and much easier to apply by machine as you can pour some onto your buffing pad.
              Paste waxes offer the characteristic of gliding action when you apply them and some people simply enjoy the aesthetics of applying a paste wax.
              There is a technique for applying a paste wax like NXT Tech Wax in which you don't scoop the wax out of the can, but instead spin your wax pad on top of the wax thus creating enough friction to liquefy it and enable it to saturate into your applicator pad. Once you have broken in a can of wax and saturated your pad a little, you will then find it takes very little wax on the pad to apply a thin coating to the entire finish.
              You just might have to try them both to see which one you prefer the most.
                Mike,
                I am only a quick study because I have a good teacher. Thanks very much for all of your help.
                Cheers!
                Autumn
