Claying prep, before and after.
  • Claying prep, before and after.
    Does it mater if you use a soap with a wash and wax ingredient before claying? Should I apply an Iron Decon, Clay and then use Surface Prep? After claying, surface prep and then NXT I found a rough spot on the hood of the car using the "hand in a plastic bag" routine. How should I start to redo that spot?
    Thank you in advance
    Re: Claying prep, before and after.
    Welcome to MOL. Check out this thread as well about the iron remover.
    General Auto Detailing Discussion. Participate in existing discussion or start a new thread with your question.
    You can clay over that area and reapply NXT. You may want to consider adding a polishing step after claying to remove and marring from the claying process.
