I'm new to detailing but trying to get some basics down as I now own a pitch black 16' Dodge Challenger. I'm practicing on my black dodge neon. I'm using the meguiars da power system on a corded drill at max rpm 2,800. I'm using the yellow pads (new pad for each trial). I clayed first. After some trial and error I found scratch x and swirl x too aggressive and left a haze. Ultimate compound work good but I found I have to work fairly quick with it before it flashes or work smaller areas. Then I used ultimate polish, seemed to work good, I wiped the remaining polish off after using the da with a fairly cheap Viking micro fiber towel but I noticed there was always an oily reside left no matter how much I wiped, flipped the towel and wiped. I'm not wiping very hard. Do I need a better towel, maybe apply a little more pressure when wiping?
Ultimate polish residue
Re: Ultimate polish residue
I'm no expert, but to me, inexpensive microfibers have no business anywhere near paint, unless it's in a door jamb. Maybe they were loading up with product and you were never removing all of it. It's also possible you may not have worked the polish long enough. I just made that mistake when polishing my truck, and removal was more difficult because of my technique.
This is one of the issues I had with Ultimate Polish. Either drying or leaving an oily residue. (I use good microfiber towels) I found that if i just left what I could not remove, and just waxed over it with Ultimate Wax, once the wax dried and was removed, everything came off and was nice and shiny with no residue. I am not a fan of Ultimate Polish. Recently I found Meguiar's Cleaner Wax M06. It is just as good, or better, in my opinion as Ultimate Polish, easier to work with, provides a wax base coat, and leaves no residue. Top it with Ultimate Wax and your black Challenger will look as gorgeous as my black Chrysler 300.
Originally posted by Mopar4u View Post...After some trial and error I found scratch x and swirl x too aggressive and left a haze. Ultimate compound work good but I found I have to work fairly quick with it before it flashes or work smaller areas...
Originally posted by Mopar4u View Post...I wiped the remaining polish off after using the da with a fairly cheap Viking micro fiber towel but I noticed there was always an oily reside left no matter how much I wiped, flipped the towel and wiped.
Hope that helps!Non-Garaged Daily Driver, DAMF System + M101, Carnauba Finish Enthusiast
4-Step | Zen Detailing | Undercarriage | DAMF Upgrade | First Correction | Gallery
Ultimate Polish is more oily than M205. If you are having a hard time removing ultimate polish, you are either using too much product or overworking it. How often did you clean your pads? Those small pads tend to load up with product fairly quickly. Clean them on the fly prior to continuing to a new panel.
This thread will give you an idea of which product is more aggressive. As you can see Ultimate Compound is actually more aggressive that those two products.
The Aggressiveness Order of SMAT Products - This might surprise you! Super Micro Abrasive Technology = SMAT From left to right, the most aggressive to the least aggressive SMAT products From the most to the least aggressive... M105 Ultra-Cut Compound/M95 Speed Cut Compound = The same in abrading power
You described Ultimate Compound flashing to quickly. Temperature and humidity come into play with polishes. That can make them a little more difficult to work with. How many passes were doing with each product? Heat can become an issue when a pad is loaded with too much product. Thus leading to pad failure but also having less working time with a product. This is why it is recommended to clean the pads frequently.
Also shrink your work area. You should not be working an area larger that shoulder width apart.
For the ultimate compound it was mid 80's, humid and in my garage. I was doing the ?cross hatch? technique, left, right then up, down, 2800 rpm moving slow. Probably a 30" x 30" area.
For the ultimate polish, same conditions, i can almost guarantee too much product for a small area, 6" x 16".
Im still learning. I do need better towels as well but picking out towels has got my head confused as much as picking out a compound/polish/wax. This detailing stuff isnt as easy as it looks.
Yes, it's very easy to get way overwhelmed. I use the lowly blue, white and brown MF "rags" from Advance Auto for most things, like interior, wiping off compound and polish, wheel touch-ups, and so on, but the celebrated Meg's Supreme Shine "towels" (upscale version of "rag") for the paint, glass, etc, in terms of final finish. The SS towels are too nice and expensive and mail order delayed across the country for most garden variety cleaning, and the cheaper rags are great for dirtier work, and I don't have to care about them. A few of the pro guys here seem to use nothing but SS towels, but then, their customers are paying for themNon-Garaged Daily Driver, DAMF System + M101, Carnauba Finish Enthusiast
Try working a 12x12 area with both products.
Originally posted by Mopar4u View PostWould I get different results if I used hex logic pads? Orange pad with the compound and white with the polish?
3". Is there a reason you want to change to a different pad?
