Hi can you use a medium cut pad to take out heavier swirl marks with UP or should I go to colorX
Pad for up
Re: Pad for up
Originally posted by Mr. Slick View PostMy favorite polishing combo is yellow polishing pad plus Mirror Glaze M205 Ultimate finishing polishDon
12/27/2015
"Darth Camaro"
2013 Camaro ... triple black
323 hp V6, 6 speed manual
Re: Pad for up
ColorX won't do much for severe swirls. I start with UP on a blue Hex Logic or Buff and shine pad on the PC 7424, or 7424xp. If I need more cut I try my compounding pad - the green Hex Logic. If that isn't working I use Ultimate Compound on the Green Hex Logic. That usually takes care of the harshest swirls, and oxidation. I play with the speeds too. I range from 4.5 - 6 for corrections, and 4 - 5 for general polishing, and 3 - 4.5 for ultra finishing. I rarely use and additional pressure with these pads.
If you go with the typical orange and white pads, be prepared to use some significant pressure.
