Needing help with my black truck
  • Needing help with my black truck
    Hi all been some time sense I've been on here. I have a black 93 ford ranger, the paint is dull I want to try to brighten it up I just bought a PC7424Xp I used Ultimate Compound by hand and it helped so I wanted to try it with the DA. What type of pad would I need to use?
    Re: Needing help with my black truck
    Use a yellow polishing pad.
      Depends on how bright or shiny that you want to get.
      If using pads from Lake Country line, then you can start from yellow pad ( the CCS Pad Style ) + Meguairs Ultimate Polish but if you want more agressive then use Meguiars Ultimate Compound as one step paint correction.
      If using Meguiars pads, then the Yellow foam pad + Ultimate Polish to start off and lets see the result from first polishing session.
