Should I add something between #80 & #16?
  • Should I add something between #80 & #16?
    Would adding something between #80 and #16 make a noticable differance? If so, what do you suggest?
    Re: Should I add something between #80 & #16?
    Originally posted by MrC
    Would adding something between #80 and #16 make a noticeable difference? If so, what do you suggest?
    M80 Speed Glaze is very rich in polishing oils, I don't think most eyes could perceive a difference if you were to polish the paint after M80 and before your choice of wax with M07 Show Car Glaze.
      Re: Re: Should I add something between #80 & #16?
      Hi Mike
      May I ask whether can I use M80 to clean my new body kit, before sending it to re-spray to my car's color since M80 is bodyshop safe?
      sky8811
        There shouldn't be a problem.
        What about the body kit needs to be cleaned before painting?
        You're painter is going to sand/scuff the panels before paint correct?
        If they are just dirty, you might want to just stick with washing with Meguiar's M0016 Hi Tech Wash as this is a body shop safe car wash.
          Thank you Mike.
          Will just wash and pass the rest to the painter.
          sky8811
