Have Rotary Buffer and DA polisher, how to best use them together & what compounds???
  • #16
    Re: Have Rotary Buffer and DA polisher, how to best use them together & what compound
    Nice!
    • #17
      test...
      • #18
        http://www.meguiarsonline.com/forums...1_beforeaa.JPG" />
        src="__________________________________"/>
        • #19
          testhttp://www.meguiarsonline.com/forums...1_beforeaa.JPG" />
          • #20
            Ralph,
            This is the way I do it:
            - Right click on your image and go to "Properties"
            - You'll see a URL for the image. Copy it.
            - Paste the URL into your text.
            - Now insert [IMG] before the URL and [/IMG] after the URL
            - For example [IMG]www.yourimageurl.com/image001.jpg[/IMG]
            - Now post your reply and that should work!
            • #21
              I still cannot get the images to show?
              As per instructions: I copy the HTML code link, I then click on the "Insert Image" icon. The code inserts fine but when I say "Save" or "Save Changes", the image never shows. All I get is a square box with an "X" in it which is a typical lost image issue of some sort? This can be seen in my last two posts...
              Ralph
              • #22
                [IMG]http://www.meguiarsonline.com/forums...1_beforeaa.JPG [/IMG]
                Davey. What exactly do you mean by "paste the URL into my text"? You mean into the body where text goes and your supposed to be able to insert images?
                Anyhow,
                I clicked on the image>properties and then copied the URL which it depicted above "http://www.....jpg
                I then put the Img in front and /Img at end. The picture still doesn't show. Your example started with www. though so I'll try removing the http://.
                Ralph
                • #23
                  I think I understand now but will have to try later. We are barbequing!!
                  Ralph
                  • #24
                    Sorry, it should have the http in there as well. Just copy & paste the whole thing:
                    Seems to work for me.
                    • #25
                      That's the link above. However, if I put the quote tags around it as you describe [IMG] and [/IMG]
                      then I still get nothing?
                      • #26
                        Maybe it's because you are putting a space before and after the URL..
                        • #27
                          Follow the earlier thread I posted and you will be fine.
                          How To - Inserting Images, Creating Photo Albums (https://meguiarsonline.com/forums/showthread.php?60104-How-To-Inserting-Images-Creating-Photo-Albums) The following shows you how to create your own photo album on MOL and also how to insert and display an image into a message. Following that is a more advanced yet, simpler
                          • #28
                            http://www.meguiarsonline.com/forums...g-Photo-Albums
                            Hey Guz. I tried that method numerous times but it has yet to work for me? I created a gallery, I then copy the HTML code for the image, I then go to the body of my reply and select "Insert Image", I then paste the HTML code in the URL box. I should at that point get a preview but nothing. Nor does anything show if I then post my message?
                            I then tried the Ultimage Quick Paste which is what Davey has been suggesting but still no luck. I will just keep trying until I figure it out. I'm running a quick i5 2.5ghz computer with Windows 8.1 so no issue there nor have I ever had an issue on any other site. My computer acts quirky with this site though because it's hard to type (literally) and then I cannot paste often. Not sure what's going on.
                            • #29
                              ding, ding, ding; we have a winner! I can copy and then paste the "Medium Image" link, which is what Davey was describing, but without having to actually type the [img] tags. The reason I couldn't paste is because you must have actual text in the body. It will not let me copy and then paste without having text...
                              Got it now. Ralph
                              **Before**
                              • #30
                                **After**
                                Just as note. This was after one pass with mixture of M101/M205 (75% and 25% respectfully) and rotary with Meg polishing pad. Running around 1,500 rpm. It wasn't my goal to get all the scratches out especially those large ones above tire, which I didn't touch. I just wanted to see how it would cut and was really impressed. There is no telling what could really be done with multiple passes or steps.
